Re: Best Daily Driver 383 cam
[Re: macmic87]
#727224
06/26/10 05:58 PM
06/26/10 05:58 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
the six pack cam i installed was recommended to be installed at 115 center line. this was according to mr sixpack based on my gear ratio and tire height.
Sorry for the confusion, I don't know the specs of the Mr six pack cam (they are not disclosed, but if you have a cam it can be measured/profiled.) I was speculating that they may be close to stock, but with more agressive lobes? Besides, I was just posting "computer simulation" results for comparison, and not having all the specific information avaliable, I had to make some assumptions on intake and exhaust port length, taper and volume. I used flow numbers from a decent flowing stock 906 head, and the 9.5:1 compression that was listed in the original post.
[Re: 451Mopar]
#727226
06/27/10 09:07 AM
06/27/10 09:07 AM
Posts: 836 lancaster, new york
macmic87
lancaster, new york
i went round and round trying to see what the exact specs were for the cam and that was a big secret. but after talking with mr six pack and alot of six pack cam users and not hearing a single complaint. i took a leap of faith and installed it. now this was after going through 2 other cams that did not respond well to the six barrel setup. the big point mr sixpack made about his cam was that it was not based on the common chevy lobe design and based on the lobe designs chryslers put out back in the day. this was to take advantage of the lifter dia. so my personal experience went well. i have alot of vacuum, an extremely smooth idle, and great tunability (is that a word?). again this is my street car and that is what i wanted for cruising. if i wanted a 1/4 killer i would have gone in different direction. here is the sheet that cam with the cam that i received.
[Re: ademon]
#727227
06/27/10 10:42 AM
06/27/10 10:42 AM
Posts: 5,949 British Columbia
chrisf
British Columbia
the vodoo cam in my near stock 383 4 speed is great! way more bottom and mid than i expected its stats are: 220/226 @.050 with 475/494 lift on a 112 lsa installed a 107
i have that same cam in a 383 and am very happy. good power. vacuum and idle. i would buy another voodoo cam in a heartbeat after using this one.
[Re: chrisf]
#727228
06/27/10 11:08 AM
06/27/10 11:08 AM
Posts: 90 NL
Frederick
NL
Just finished a 383 also with the Lunati 60302 (262/268 220/226 @.050 0.475"/0.494") Happy so far, break-in went fine, idles at 800rpm. No ticking lifters like I have heard on the comp XE series. How much vacuum are you pulling ChrisF? I'm getting 15" and a cranking compression of 145psi, seems a bit low to me? 383 +030, 9.58:1 compression, cam installed 108
383B, 9.8:1, Lunati 60302(220/226@0.050 262/268Dur, 0.475"/0.494", Stealth heads, Performer manifold, QF SS-750-AN carb, 3.31Diff, A833 4-speed manual.
[Re: chrisf]
#727229
06/28/10 12:41 AM
06/28/10 12:41 AM
Posts: 352 Arizona
69rrgrabber
Arizona
Hey, on that Voodoo cam, did you have to do anything special to the heads for the extra lift? Are the stock rockers fine? Do you need the matched springs? Carl
"It takes a Mopar to catch a Mopar!"
1969 Charger R/T 440
1969 Road Runner 383
1970 Cuda 440
[Re: 69rrgrabber]
#727231
06/28/10 05:21 AM
06/28/10 05:21 AM
Posts: 90 NL
Frederick
NL
Stock rockers here too. Stock springs won't work. Suggest you use the springs Lunati recommend or something similar. I'm using 26918 Comp Beehives and 440 source heads. Thanks for the details, Ademon. Must be my lower compression then and testing cold.
[Re: macmic87]
#727233
07/10/10 09:47 AM
07/10/10 09:47 AM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
Good Deal!! What size and type of carb you are running on your combo? (Vac sec or air door type- AVS/AFB) Might of missed it in your post. It's the amount of vacuum that interests me, for the carb I would go with. Can't go wrong with it!!
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
