Best Daily Driver 383 cam
#727183
06/18/10 12:13 AM
06/18/10 12:13 AM
Posts: 352 Arizona
69rrgrabber
Arizona
Any one have a favorite cam for a 383 daily driver? The car is a 69 Road Runner, with auto and 323 posi. It will be used for crusing cross country, stop lite to stop lite low end speed. Looking for good torque at low and mid RPM. This is what I have, stock 69 383, 9.5:1 CR, 3 angle valve job on stock heads, DP4 Eddie intake, 600 Holley, Headman Elite Headers, dual exhaust, x pipe, have stock 12 inch and 11 inch converter, auto, 323 posi. I already have a 440 car so max power isn't as important as max torque in this case. Thanks, Carl ![](/ubbthreads/images/graemlins/2241092-prplchrgr.gif)
"It takes a Mopar to catch a Mopar!"
1969 Charger R/T 440
1969 Road Runner 383
1970 Cuda 440
Re: Best Daily Driver 383 cam
[Re: TMBOOTS]
#727188
06/18/10 10:30 PM
06/18/10 10:30 PM
Posts: 352 Arizona
69rrgrabber
Arizona
Thanks for all the responses. I tried the online computer dyno to try to get an idea on how much torque vs horsepower the cams would give (ball park). All are in a good range,all will give, according to the program, 370 to 397 hp and 440 to 480 lbs torque, but the bigger 280 cam gives about 29 hp over the smaller 262 cam, and the smaller cam gives about 40 lbs of torque over the biggest. The Hughes cam and Voodoo cam are in between. What is better for a cruiser? gain 40 lbs torque or 27 hp? Maybe a better question is about how much torque does a 383 need to put out to push the Road Runner with ease? Thanks Carl ![](/ubbthreads/images/graemlins/boogie.gif)
1970 Cuda 440
[Re: intragration]
#727192
06/19/10 04:16 PM
06/19/10 04:16 PM
Posts: 902 Seattle, WA
rss
Seattle, WA
It's a great cam, I just started driving my 440 'Cuda with a Mr. Six Pack. I wonder how it would run in a 383...
What are your thouhts on the Mr. 6 Pack cam? Is it really much different than the stock HP cam?
[Re: intragration]
#727194
06/19/10 06:12 PM
06/19/10 06:12 PM
rss
Seattle, WA
it seems to have a bit of an idle-thing going on, in a good way, more than I would think you'd see in a stock car.
Not sure I'm following you.
Most stuff I've read regarding the Mr. 6 Pack cam is that it has a super smooth idle. Some have described it as idling like a 6-cylinder or 318 stocker.
[Re: rss]
#727195
06/19/10 10:10 PM
06/19/10 10:10 PM
Posts: 352 Arizona
69rrgrabber
Arizona
Is there a web site to order a Mr Six Pack cam?
Thanks Carl
1970 Cuda 440
[Re: rss]
#727197
06/20/10 01:34 AM
06/20/10 01:34 AM
Posts: 242 midwest
intragration
midwest
I have stock quiet mufflers right now, and there's no mistaking my motor for a 318. It's not wild and crazy, but there's definitely something going on there. I'll know more once I get the new exhaust on. Here's his info, I don't represent him or have any affiliation with him, just a very satisfied customer. I just called him up and ordered with a credit card. He even spent time talking to my engine shop during the build process, giving recommendations and advice: Mr. Six Pack Bob Karakashian (248) 477-7776 mr6pk@hotmail.com
[Re: intragration]
#727198
06/20/10 02:22 AM
06/20/10 02:22 AM
rss
Seattle, WA
Thanks for the info. I'm going to give him a call to see if he thinks his cam will work well for my 383 build. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: rss]
#727199
06/21/10 12:22 AM
06/21/10 12:22 AM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
Bob is a great guy. After talking with him on the phone I bought his cam two years ago for my street 383 build. It's not done yet so I can't say how well it runs in in a 383. He did tell me his cam is in many 383 engines. BTW, Bob does not grind his own cams, he has Ingle Cams grind it for him using his top secret specs. ![](/ubbthreads/images/graemlins/thumbs.gif)
Read more:
Bob Karakashian - Part 1
Bob Karakashian - Part 2
![](http://competitionsynthetics.com/images/BOBSLOGOWEB_2.jpg)
[Re: CompSyn]
#727200
06/21/10 12:38 AM
06/21/10 12:38 AM
rss
Seattle, WA
C'mon, get that thing buttoned up so you can let me know how she runs. ![](/ubbthreads/images/graemlins/drive.gif)
[Re: 69rrgrabber]
#727201
06/21/10 09:41 AM
06/21/10 09:41 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
Thanks Carl
torque. where is the 27HP advantage? probably over 5000 RPM. how often do you buzz your motor up there? where is the 40 lb-ft advantage? probably in the 3000-3500 RPM range, where you're at a lot more. the midrange torque advantage also translates to a midrange HP advantage. I'd use a comp XE262 or voodoo 60302 if looking at an off the shelf grind.
[Re: 69rrgrabber]
#727202
06/23/10 09:56 PM
06/23/10 09:56 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
Thanks Carl
Hands down, gaining the 40 ftlbs of torque! You need it for "powering thru the gears", passing, or just plain hi-speed cruising (60+ mph or higher) on the highway!! But idle content is important too, so is quiet operation till you put foot in it!! I have to agree with some of the other members on the cam from Mr. Six Pack. Not that I am posting a plug for him, it just makes sense!! Especially with the 3.23's!!! All I can say is do more research on his camshafts. ![](/ubbthreads/images/graemlins/thumbs.gif)
![](/ubbthreads/images/graemlins/2245452-furysmiley.gif)
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
