Re: Minium rear tire pressure
[Re: flatiron]
#727173
06/18/10 12:14 AM
06/18/10 12:14 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
Just wondering what would be the least amount of air you would run on the rear of a 72 Dart I'll say the weight is about 3200 lbs the tires are M/T Et drags 26x8.5-14
depending on the gauge I would use 10 lbs. as the minimum, be careful at that pressure when under acceleration and deaccelleration they will probally wiggle some. I had a old timer give me some very good advice on using small wrinkle wall tires at low pressure, he siad the back has to follow the front if you keep the steering wheel straight, don't try and correct the car under acceleration or deacceleration at the track unless it is going to hit something. Steer it very gently, don't jerk the steering wheel around, steer it gently and gradually a little bit at a time
[Re: flatiron]
#727174
06/18/10 12:18 AM
06/18/10 12:18 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Minimum is going to be very different for each chassis/motor combination.
A low pressure one guy could get a way with will crush the tire for another.
Besides, it's not how low you can run, it's how high can you get it before it doesn't hook. Also remember that a lower pressure could 60' better but give up MPH out the back.
Higher pressures are more stable a speed as well.
IMHO, bump up in 1/2 # increments till the car/timeslip tells you you went to far and back down a tad.
[Re: flatiron]
#727175
06/18/10 12:19 AM
06/18/10 12:19 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Really your looking at it backwards... you should be trying to run the most air pressure you can and still hook up... you will MPH higher with more air and not to say its more stable on top end
[Re: MR_P_BODY]
#727177
06/18/10 03:04 AM
06/18/10 03:04 AM
Posts: 4,647 aotearoa
rebel
aotearoa
i always thought you look for even tread/slick wear for an even pattern. somewhere that shows the slick is wearing evenly across it's depth dots. this would show your slick is maximising it's surface area of contact for traction, which is what we're striving to achieve yeah? too much pressure & the center of your slick is going to dissappear quickly so traction is only short lived with a newish slick. maybe i'm just being tight on my tire budget but i was getting good traction & life from slicks on my 'cuda running them @ 10.5-11.00 psi, they were 28x12.5 size slicks unless this is the kind of pressure P Bods suggesting?
[Re: rebel]
#727178
06/18/10 07:53 AM
06/18/10 07:53 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
M/T tires like air pressure but you can run to much. You should take the car out and start at your current tire pressure and make a pass and come back and take a pound out. Do this and keep track of your sixty foot times to see where it is the fastest. With those tires a think they would start to wod up at around 11psi. We run the 28*9 M/T tires on one of our cars and keep them at 13psi. With leaf springs and a small block at 3200lbs it runs 7.20's in the 1/8th and 60' very well and consistently. Hope this helps.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
