Page 1 of 3 1 2 3
How to determine a real Six-Pack block? #72691
06/12/08 11:58 PM
06/12/08 11:58 PM
Anonymous OP
Anonymous OP
Hi guys,
Was wondering what stampings one could look for to determine if a 1970-era (cast in '69) was actually a 440 six-pack block?
Thanks!
Re: How to determine a real Six-Pack block? #72692
06/13/08 12:08 AM
06/13/08 12:08 AM
Carlisle, AR.
mdwyer Online happy
mdwyer  Online Happy
Carlisle, AR.
I think the only way would be the vin number.
mike
1970 Challenger T/A
1970 Roadrunner RM21 Vcode
1971 Gtx
1971 Satellite
1971 Charger 500 GB5 383 A54 car
1972 Satellite
1997 Dodge 1500 hunting rig
2014 Ram 2500 Mega Cab
Re: How to determine a real Six-Pack block? [Re: mdwyer] #72693
06/13/08 01:08 AM
06/13/08 01:08 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If we are talking about a bare block that is the only correct answer lies within the VIN#, or more specifically, the blocks VIN sequence number matching the VIN# of an original Six Pack car..
Re: How to determine a real Six-Pack block? #72694
06/13/08 01:48 AM
06/13/08 01:48 AM
south carolina
gastongremlin Offline
south carolina
i don't know if this is 100% true all of the the time but the few i've seen were marked 440-6 on the flat area in front of the drivers side head area.
Re: How to determine a real Six-Pack block? #72695
06/13/08 01:55 AM
06/13/08 01:55 AM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
I don't think you can....why would the factory need to make a distinction between a 440 six pack and a 440 4 barrell block??? it's the SAME block...and other than an "HP" stamp, the lo-po 350 horse 440 used the same block.
Re: How to determine a real Six-Pack block? [Re: cornucopia] #72696
06/13/08 01:58 AM
06/13/08 01:58 AM
south carolina
south carolina
the true 6 pack blocks have a high nickle content in the iron.
Re: How to determine a real Six-Pack block? [Re: gastongremlin] #72697
06/13/08 02:01 AM
06/13/08 02:01 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
That's not true compared to the lo-po or even 4v blocks. They are the same blocks, same cores, same foundries.
Only way to know is how Scott mentioned above, have to tie the partial VIN to a complete V code VIN.
Re: How to determine a real Six-Pack block? [Re: RobX4406] #72698
06/13/08 02:26 AM
06/13/08 02:26 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: How to determine a real Six-Pack block? [Re: 1_WILD_RT] #72699
06/13/08 05:53 AM
06/13/08 05:53 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
it will have " " logos all over it..
I am truckless..
Re: How to determine a real Six-Pack block? [Re: 340SHORTY] #72700
06/13/08 07:23 AM
06/13/08 07:23 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
As pointed out earlier, there is no differance between a HP block and a six pack block. People always said HP2 denoted a six pack block, but that just meant it was assembled on the second shift. I read an article many years ago where they interviewed a Chrysler engineer who was part of the perfomance program. He stated that the HP blocks were visually inspected for minimal core shift. He said they would look at how many HP engines they needed for production requirements that week, look through their available blocks, visually inspect them, stamp them HP and segregate them. The block in a lo po Imperial may have met the standards for an HP, but if it was not inspected because they had already picked their quota, it was not marked. Based on the production standards at the time, I believe this to be true.
Re: How to determine a real Six-Pack block? [Re: 1_WILD_RT] #72701
06/13/08 07:31 AM
06/13/08 07:31 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: How to determine a real Six-Pack block? [Re: moparmarks] #72702
06/13/08 07:55 AM
06/13/08 07:55 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Moparlee
Re: How to determine a real Six-Pack block? [Re: Robbins] #72703
06/13/08 08:15 AM
06/13/08 08:15 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I have also heard someone ellode to there being an A or maybe AA stamped somewhere on the bottom around the pan rail oil pump area. I don't know if it was an inside joke or not , bu they treated it like a decoder ring or secret handshake. SHHH others are listening! I have also heard that many but not all are HP2 blocks, but to my knowledge, matching the VIN to a known VIN is the only factual way to know.
Careful, your character's showing!
Re: How to determine a real Six-Pack block? [Re: mopar346] #72704
06/13/08 08:25 AM
06/13/08 08:25 AM
MN
ryangtogtx Offline
ryangtogtx  Offline
MN
When will this HP2 business die? As mentioned earlier, HP2 denotes second shift, not six-pack. This is a fact, not fiction. The only way to know for sure is to match the vin sequence with an existing documented car.
Re: How to determine a real Six-Pack block? [Re: ryangtogtx] #72705
06/13/08 09:21 AM
06/13/08 09:21 AM
Anonymous OP
Anonymous OP
On the "HP" or "HP2" stamp ... where exactly should this be located? Should this be near the Casting Date on the Passenger Side or somewhere else?
Thanks!
Re: How to determine a real Six-Pack block? #72706
06/13/08 09:31 AM
06/13/08 09:31 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's a 70 440 block stamped with HP2, guess which car it came in (Six Pack or 4 barrel) and then explain how you came to either conclusion
Re: How to determine a real Six-Pack block? [Re: ScottSmith_Harms] #72707
06/13/08 10:07 AM
06/13/08 10:07 AM
mopar346 Offline
mopar346  Offline
HP2 IS simply the designation for the second and most informed know that, many engines HP and otherwise were built on that shift. I have commonly heard that a great percentage of the A12 motors were assemblied on the second shift, BUT NOT ALL, true or not I am just restating what I haved heard, but qualifying it as such. Sometimes when statements like that are aired out, someone with some facts will come forward to discredit it, that is one of the good things about this forum, there are many people in the know on here. HP2 confirms or denies anything, it is just what I have heard as a common theory. Fill me in though, I have no problem being corrected, just ask my wife.
Has anyone else heard of the A or AA stamping????
Re: How to determine a real Six-Pack block? [Re: ScottSmith_Harms] #72708
06/13/08 11:32 AM
06/13/08 11:32 AM
Anonymous OP
Anonymous OP
Six pack car. How I came to my conclusion...
Either a coin toss, or the fact that you posted the pic, giving a slight edge to the fact that you took the picture BECAUSE it was a six pack
Re: How to determine a real Six-Pack block? [Re: gastongremlin] #72709
06/13/08 11:53 AM
06/13/08 11:53 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
and where did you hear this little tidbit of info ???
Re: How to determine a real Six-Pack block? #72710
06/13/08 11:53 AM
06/13/08 11:53 AM
JohnRR Offline
JohnRR  Offline
Hi guys,
Thanks!
by the FULL CHRYSLER ASSIGNED VIN of the car it came out of ...
Page 1 of 3 1 2 3
