1970 Cuda - where to get steering shaft roll pin remova #72565
06/12/08 10:14 PM
06/12/08 10:14 PM
Anonymous OP
Anonymous OP
We are trying to remove the roll pin that fastens the steering lock plate in place on the steering shaft. The manual says not to try and knock it out with a punch (I can see why because there is nothing to brace it against). The manual calls for steering shaft to lock pin plate tool. special tool number C-4113.
Where can we find this tool?
Rebecca
Re: 1970 Cuda - where to get steering shaft roll pin re #72566
06/13/08 01:27 AM
06/13/08 01:27 AM
California
sixpaktoogo Offline
sixpaktoogo  Offline
California
I have used a punch to knock the pin out (and re-install it)on more than 30 cars without a problem.
Re: 1970 Cuda - where to get steering shaft roll pin remova #72567
06/13/08 03:16 AM
06/13/08 03:16 AM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
These are the folks that made all or most of the Mopar specific tools, yours isn't listed.
Miller SPX
Re: 1970 Cuda - where to get steering shaft roll pin remova #72568
06/13/08 07:29 AM
06/13/08 07:29 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
It'll come out with a punch, but it has to be a roll pin punch. Looks like these:
Re: 1970 Cuda - where to get steering shaft roll pin re [Re: sixpaktoogo] #72569
06/13/08 07:30 AM
06/13/08 07:30 AM
Anonymous OP
Anonymous OP
The shaft is still in the the car. The manual says not to use a punch. I am thinking that this is because if you tap it the shaft just wiggles (not rigedly held) and perhaps stresses the other end of it. Did you have the shaft out of the car when you punched it out?
Thanks,
Rebecca
Re: 1970 Cuda - where to get steering shaft roll pin remova [Re: Challenger 1] #72570
06/13/08 07:32 AM
06/13/08 07:32 AM
Anonymous OP
Anonymous OP
thanks for the pic. my punches look different. I guess they are not roll pin punches. I will get some and then ponder some more about whether I should try and tap it out with the shaft still in the car (unbraced - kind of hard to tap it).
Rebecca
Re: 1970 Cuda - where to get steering shaft roll pin re #72571
06/13/08 08:39 AM
06/13/08 08:39 AM
California
70SportSatellite Offline
super street
super street
California
Really isn't an issue. With everything in place it can be tough to access. Some punches are hex shaped and I've found a socket to fit it and used an extension, worked fine. When hitting you will be applying some forces to the input shaft of the steering gear but the pin should move easily enough without causing any damage. Like said already, done a number of times with no problems. Good luck.
Re: 1970 Cuda - where to get steering shaft roll pin re [Re: 70SportSatellite] #72572
06/13/08 08:36 PM
06/13/08 08:36 PM
Anonymous OP
Anonymous OP
Sounds like we found the solution. Thanks so much. I will look for a proper set of roll pin punches this weekend. Our ultimate goal is to replace the fried ignition switch.
Rebecca
Re: 1970 Cuda - where to get steering shaft roll pin re #72573
06/14/08 12:03 AM
06/14/08 12:03 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
A drill blank works great for me
NS1AAR
Re: 1970 Cuda - where to get steering shaft roll pin re #72574
06/14/08 10:21 PM
06/14/08 10:21 PM
Groton, MA.
BHuey Offline
BHuey  Offline
Groton, MA.
Say hi to Rich and let us know how it works out Rebecca.
Lyle
70 Challenger R/T Conv. 66 Vette 427 Coupe 61 Vette FI Roadster
