1970 Cuda - where to get steering shaft roll pin remova
#72565
06/12/08 10:14 PM
06/12/08 10:14 PM
We are trying to remove the roll pin that fastens the steering lock plate in place on the steering shaft. The manual says not to try and knock it out with a punch (I can see why because there is nothing to brace it against). The manual calls for steering shaft to lock pin plate tool. special tool number C-4113. Where can we find this tool?
Rebecca
Re: 1970 Cuda - where to get steering shaft roll pin re
[Re: sixpaktoogo]
#72569
06/13/08 07:30 AM
06/13/08 07:30 AM
The shaft is still in the the car. The manual says not to use a punch. I am thinking that this is because if you tap it the shaft just wiggles (not rigedly held) and perhaps stresses the other end of it. Did you have the shaft out of the car when you punched it out?
Thanks, Rebecca
Re: 1970 Cuda - where to get steering shaft roll pin remova
[Re: Challenger 1]
#72570
06/13/08 07:32 AM
06/13/08 07:32 AM
thanks for the pic. my punches look different. I guess they are not roll pin punches. I will get some and then ponder some more about whether I should try and tap it out with the shaft still in the car (unbraced - kind of hard to tap it). Rebecca
[Re: 70SportSatellite]
#72572
06/13/08 08:36 PM
06/13/08 08:36 PM
Sounds like we found the solution. Thanks so much. I will look for a proper set of roll pin punches this weekend. Our ultimate goal is to replace the fried ignition switch.
Rebecca
#72573
06/14/08 12:03 AM
06/14/08 12:03 AM
Posts: 1,145 ontario calif
ns1aar
ontario calif
A drill blank works great for me
NS1AAR
#72574
06/14/08 10:21 PM
06/14/08 10:21 PM
Posts: 126 Groton, MA.
BHuey
Groton, MA.
Say hi to Rich and let us know how it works out Rebecca. Lyle
70 Challenger R/T Conv.
66 Vette 427 Coupe
61 Vette FI Roadster
