Re: Can't get rid of a miss!!! Help!
[Re: 05dakota]
#724826
06/15/10 03:32 PM
06/15/10 03:32 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Never seen a kit that include a vr.
That is because the VR is irrelevant. The ignition system doesn't care it there is a charging system there or not as long as the battery has enough voltage to fire the ignition.
[Re: MoparforLife]
#724827
06/24/10 09:51 PM
06/24/10 09:51 PM
Posts: 130 Marcell, MN
68 Roadrunner
Marcell, MN
Well after trying every possible option with my electronic ignition, I took it all out and put in my old worn out points distributor. It runs 100% better. I finally got to melt some rubber off the tires! The new motor combo seems to make good power. I will definately need to upgrade to some stickier tires! It will spin through all 3 gears. Now I have to see if Jegs will take this Proform kit back. There has to be something defective in the kit. I am assuming it is the ignition module...but I don't know for sure.
1968 Roadrunner 383 auto
.060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
[Re: ireland383]
#724829
06/24/10 10:20 PM
06/24/10 10:20 PM
68 Roadrunner
Marcell, MN
Thanks! It isn't running "perfect"...but atleast it is running and driveable!
[Re: Paul_Fancsali]
#724831
06/25/10 02:51 PM
06/25/10 02:51 PM
68 Roadrunner
Marcell, MN
No it only has 4. I have the company sending me a new ignition module for free. I will try it and see what happens. If it still runs bad, then I am going to order a reman. distributor and a pertronix kit. (my old stock dist. is worn out)
