TOTAL ADVANCE-WHAT RPM #724783
06/15/10 08:44 AM
06/15/10 08:44 AM
Maryland
cudaboone Offline OP
Maryland
When setting total advance, what rpm should it be set at?
Re: TOTAL ADVANCE-WHAT RPM [Re: cudaboone] #724784
06/15/10 09:42 AM
06/15/10 09:42 AM
Actually you just want to choose springs that will keep you just under the pinging point @WOT on your hottest/driest day going up thru the gears at whatever RPM that lets it max out at which may be in the ~1500-2500 range.
Re: TOTAL ADVANCE-WHAT RPM [Re: cudaboone] #724785
06/15/10 02:45 PM
06/15/10 02:45 PM
Maryland
Maryland
Thanks, please don't laugh. i have three sets of springs. How does the different size springs effect the advance?
Re: TOTAL ADVANCE-WHAT RPM [Re: cudaboone] #724786
06/15/10 03:30 PM
06/15/10 03:30 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""How does the different size springs effect the advance?""
The heavier the spring(s) tension are, the longer it takes for the advance plates to extend which delays the rpm of the timing.
Light springs = early full timing advance
Heavy springs = later full timing advance
Re: TOTAL ADVANCE-WHAT RPM [Re: YO7_A66] #724787
06/15/10 06:59 PM
06/15/10 06:59 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
You can mix or match the springs. Such as a light and heavy springs together, or medium and light springs together, or two heavy springs and so on.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: TOTAL ADVANCE-WHAT RPM [Re: cudaboone] #724788
06/15/10 07:31 PM
06/15/10 07:31 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
The curve can be set for the timing to follow the torque curve before it peaks. If your engine is built , it wants more fuel, then needs more time to burn the fuel. 36-38 total offers the best advantage for the flame to achieve volumetric efficiency. Cruising vacuum alterations , hot no crank starts , fuel, and detonation keep you from locking it out at 36.
You will find a run-of-the-mill 268 cam may like 18-20 initial with a 850-1000 rpm idle. Have it all it by 2200, which should be when the converter starts locking. try a 14 deg locking plate to limit the extra advance from the curve. After 2200rpm you will stay under 34 deg. away from detonation.
If you can not hot start at 20 initial mechnical, use a MSD starter retard device. If you overheat at 20, fortify your cooling system.
Run a vacuum advance if you drive it on the roads. Adjust it for cruising. You can run ported or full vacuum, but set it with the FULL vac advance at idle in mind. At WOT the vacuum gets down to zero, then it is out of the way.
Re: TOTAL ADVANCE-WHAT RPM [Re: mark7171] #724789
06/16/10 07:58 AM
06/16/10 07:58 AM
Maryland
Maryland
How do you know all this stuff?
It is a 528 hemi. 10.75 Compression
comp roller cam installed @110.0. valve timing @ .050 Int: open open 14 close 54. exh open 54 close 14
gross valve lift .604 intake .585 exhaust.
tappet lift 286 286
1050 holley dominator.
5 speed trans.
Indy cylinder heads.
What will cause detonation? Too much advance or not enough advance?
Non vacuum MSD distributor.
If anyone has a 528 similar, what is your setting at 850 RPM? What is your total advance?
6039760-cudapictures.mht (122 downloads)
Re: TOTAL ADVANCE-WHAT RPM [Re: cudaboone] #724790
06/18/10 01:53 PM
06/18/10 01:53 PM
Maryland
Maryland
How about a little guidance? I am into something foreign to me.
6043479-cudapictures.mht (113 downloads)
Re: TOTAL ADVANCE-WHAT RPM [Re: cudaboone] #724791
06/18/10 03:14 PM
06/18/10 03:14 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Too much advance can, and too low grade of gasoline can also.
Bump you the timing a little bit at a time to see how the engine likes it. If it kicks back against the starter or it starts rattling, back it off a bit until all is well.
Re: TOTAL ADVANCE-WHAT RPM [Re: cudaboone] #724792
06/18/10 03:31 PM
06/18/10 03:31 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
10.75:1 compression, high timming, and pump gas.
Re: TOTAL ADVANCE-WHAT RPM [Re: cudaboone] #724793
06/18/10 03:42 PM
06/18/10 03:42 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
tappet lift 286 286
5 speed trans.
Get a MSD limiter bushing from FBO(4secondsflat) cause your gonna need a short curve. limit it to 10 degrees more plus an initial of 24. A 14deg limiter bushing with 22 inital could work well too.
Then there is possiblility you may need a MSD starter retard device. Then you can hot start , comming back from the piggly wiggly. Instead of crudely turning the distributor back by hand for the hot start.
Re: TOTAL ADVANCE-WHAT RPM [Re: mark7171] #724794
06/18/10 05:36 PM
06/18/10 05:36 PM
Maryland
Maryland
I just set the idle timing 850RPM at about 22 BTDC and it seems to idle nicely and steady. I like the idea of the 14 degree limiter. How does this thing work and where to get it. I will surely have it by midweek.
Seems to start good when hot withing a few minutes, but after sitting a while and still pretty hot, she can be a little [Edited by Moparts - Family Friendly Site - Keep it clean] to start. That was at 18 BTDC, maybe at 22 it will start better hot!!
Right now i have to two heaviest springs?
Re: TOTAL ADVANCE-WHAT RPM [Re: cudaboone] #724795
06/18/10 05:46 PM
06/18/10 05:46 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
Have you taken off the distributor cap , or switched advance springs on the weights? Have you ever built a engine yourself?
MSD has a bushing on a peg , controls the total advance amount by how much the weights fly out , adjusts with bushing thickness. 4secondsflat.com sells the part. Don, is a nice guy to seek addvice. Some limiter bushins should come with the MSD unit.
AT 22 initail it will start harder hot. At that level you need a MSD starter retard device. This retards the ignition 10-25 degrees while cranking. So 22 initial will start hot like it was 12. It will crank hot like the spark plugs are out. This saves your starter and flywheel big time.
http://www.summitracing.com/parts/MSD-8984/
One concept you should be familiar with . An engine requires different timming at WOT than at cruise. A vacuum advance usually conrols additional advance past the total mechanical to relax the beast at road speed.
Re: TOTAL ADVANCE-WHAT RPM [Re: mark7171] #724796
06/18/10 06:06 PM
06/18/10 06:06 PM
Maryland
Maryland
I have learned that on this site. However, my distributor does not have vaccum pot and the engine does not have any way to get vacuum. Neither The 1050 dominator nor the dominator intake have any vacuum connectors?
I found the FOB site and will get the 10 and 14 degree advance things. Me taking my distributor apart should be a made for TV event.
I have never built and enging and have never taken a dist apart, but i am pretty mechanically minded except for electrical.
If i try to go to 12 BTDC, she will not even run.
6043792-cudapictures.mht (94 downloads)
Re: TOTAL ADVANCE-WHAT RPM [Re: cudaboone] #724797
06/18/10 06:30 PM
06/18/10 06:30 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
Everybody needs a place to start , right? Why not a 528 hemi DREAMCAR.
It will start fine with the MSD device. the retard only happens during crank. once lit the carb should choke and high idle out of the crank. Hot the high idle wont be an issue it seems to be above 800rpm.
They sell 1" carb spacers with ports for pvc and brake booster.
Re: TOTAL ADVANCE-WHAT RPM [Re: Junky] #724798
06/18/10 06:44 PM
06/18/10 06:44 PM
Arizona
az426john Offline
az426john  Offline
Arizona
From all the advise I was given last month on basicially this same subject for my 426 Hemi the answer is generally 31 - 34 degrees of total timing at whatever RPM yours is all in at.
You will need a back dial timing light and/or a timing tape on the motor. I would expect the advance to be all in before 3000 RPM. Then run it and see if it pings. If it does, retard it a little at a time until it quits.
There is a bunch of information on this site on whatever subject you are interested in by using the search function. When you find folks who really know what they are talking about you can search on their names also.
Hope this helps. You have gotten some good advise by others.
John
Re: TOTAL ADVANCE-WHAT RPM [Re: mark7171] #724799
06/19/10 01:16 AM
06/19/10 01:16 AM
Maryland
Maryland
I bought my cuda about 15 years ago and have gradually worked on it.
I think that i did have those little round bushing that came with the dist, but i have looked high and low with no find. I have such a mess in my garage. I'm sure they will show up after i buy the new one.
I only have a little more than 3 1/2 inches from top of carb to top of hood,even with the cowl induction hood. The short air cleaner i have just barely rubs the top of the hood. So, i can't put a carb spacer unless i get a taller cowl induction hood which i can't afford right now.
I should have gotten the smaller intake instead of the dominator. I think it is a little shorter.
Monday, i am going to order the shims from FOB. The 10 and 14 for 29.00. Do you have to remove the dist to change the bushing?
I have 6200 RPM chip in it right now and i think i hear a little pinging at about 6000. I am going to start with the 14 spacer. That would be about 36 total advance if i use 22 BTDC. Seems like it hits 6000 in a microsecond. Maybe i will use the 10 spacer and go to 24? 34 total might be better?
If all else fails, i will get the MSD box-battery saver.
Is this box hard to install. What i mean is, does it have a lot of wiring.
6044380-cudapictures.mht (77 downloads)
Re: TOTAL ADVANCE-WHAT RPM [Re: cudaboone] #724800
06/19/10 02:04 AM
06/19/10 02:04 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
The box is easy to install retard box red wire to thin MSD 6al "thin red" +. Yellow retard box to white 6al, black to engine ground. 15 minutes tops. No soldering, snap on posi lock connectors are include to splice neatly into the harness. PLease read the instructions avalible on website.
Yes, its been done. You have to work upside down because the bushing and retaining nut is underneath. Try not to drop the new one durring installation. Much easier if pulled.
My experience only reflects what things my cars had wrong . While trying to correct their problems , these were my conclusions. If it sounds similar to your situation, or makes sense in some way , give it a shot.
For vacuum , it is possible to drill and tap your single plane intake for a npt fitting.
Microseconds sound right FOR A 528 HEMI. Godspeed.
Re: TOTAL ADVANCE-WHAT RPM [Re: mark7171] #724801
06/22/10 04:32 PM
06/22/10 04:32 PM
Maryland
Maryland
Had a long talk with FBO yesterday. He wanted to know everything about my 528 hemi before giving an answer. cam, compression, transmission, tires etc.
He said i need an initial timing of 22 and 10 degrees mechanical. I ordered the 10 and 14. If i am still having hot start problem, i will get the retard.
Very nice people to deal with.
6049676-cudapictures.mht (79 downloads)
Re: TOTAL ADVANCE-WHAT RPM [Re: mark7171] #724802
06/30/10 03:52 PM
06/30/10 03:52 PM
Maryland
Maryland
Got the parts from FOB. Believe it or not, i took the dist out, took it aprt and installed the 10 deg bushing. Had to do a little filing, it so big. Don at FOB told me what to do. Haven't had a helper yet to try and set it at 32 deg total. Did set idle (about 900 RPM) at 22 and it seems to like it there.
Will that retard box work with my summit dig inig box (street & strip)?
