Re: Quick fuel E85 metering blocks on 4150 holley results ?
[Re: rt66jim]
#724165
06/14/10 03:22 PM
06/14/10 03:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Perhaps 440Jim will see this and offer his experience. I would go to the E85 Forum. Alot of help over there. But from what I've read it will probably require a booster change as well. Jim
Yeah it should have boosters also
[Re: E-85 408 DART]
#724166
06/14/10 07:04 PM
06/14/10 07:04 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
this is the set up on my dads car
I am using a stock Holley base plate with the Proform 750 main body,
Quick Fuel blocks
.130 SS needles,
57/28 air bleeds,
QF 4 window 4.5 PV in primary side,
88/94 MJ , also using 30cc pumps with the green diaphrams,
I also use a Holley blue pump with the cheap regulator that comes with it.
#45 shooters
best on E85 off the trailer with NO TUNING yet is 11.12
on gas was 10.98
i started 10 jet sizes bigger
the boosters in the 750 proform main body are plenty for E85 for that size carb
DIY and save some money
WAXER
