Post deleted by Defbob
[Re: Todd]
#724046
06/14/10 11:39 AM
06/14/10 11:39 AM
Re: Any idea how to fix this?
#724048
06/14/10 11:47 AM
06/14/10 11:47 AM
Posts: 876 Arizona
PolyDart
Arizona
I would JB Weld a stud in there and use a nut...
If you haven't used JB weld before, install your stud and let it sit 24 hrs before touching it again. The stuff works great, but needs time to cure.
[Re: Todd]
#724050
06/14/10 12:02 PM
06/14/10 12:02 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You may have enough material below to just drill and tap farther down the hole... then if you wanted to add some JB weld to make it look nicer... either way locktite and a a stud
[Re: B G Racing]
#724052
06/14/10 12:42 PM
06/14/10 12:42 PM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
Clean it real good,weld it up, dress it with a diegrinder,drill and tap it,locktight a stud in it.Good to go
X2, ben dare done dat
