383 dome pistons Edelbrock heads #723775
06/13/10 10:10 PM
06/13/10 10:10 PM
fullfloater Offline OP
Just fired up 383 ,Roller edddy heads etc ,Its got i beleive 2295 old school pistons ,I know these pistons had a slot in them for sparkplug ,never even thought about this when clayed for clearance ,had a miss ,found a plug with the electrode bent over ,i hope i dropped it and missed it ,but i,m thinking its kissed the piston ,didn,t see any marks on it ,but got me concerned with these angle plug heads ,any ideas here ,smaller plug ,don,t want to pull motor apart to grind clearance for plugs ,might have too ,thanks
Re: 383 dome pistons Edelbrock heads [Re: fullfloater] #723776
06/13/10 10:18 PM
06/13/10 10:18 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I can tell you you don't want to run a plug like the short reach ones an iron head uses.
DAMHIK
Re: 383 dome pistons Edelbrock heads [Re: fullfloater] #723777
06/13/10 10:30 PM
06/13/10 10:30 PM
arizona
stockerbill Offline
stockerbill  Offline
arizona
I did the exact same combo for a friend, only with a old 590 cam and felpro blue cheap rebuild gaskets and had no problems. It is been beaten on for over a year now. If you don't think you dropped 1 plug,I would frop the pan and check the rod brng. on that cyl! Or, replace the plug,give it a rev and look at the plug again. You wont have to grind the pistons, at the most, just index them like a sbc
Re: 383 dome pistons Edelbrock heads [Re: fullfloater] #723778
06/13/10 10:42 PM
06/13/10 10:42 PM
ill
dennismopar73 Offline
ill
best guess it hit
with dome piston cant run extended tip plug
without cutting piston
i have almost the same combo
Re: 383 dome pistons Edelbrock heads [Re: fullfloater] #723779
06/13/10 11:54 PM
06/13/10 11:54 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
Hey!
I run that those pistons and heads on my 383 and I had to clearance the pistons.
Hope everything is ok!
Paul
'69 Super Bee 383 EFI Turbo
Re: 383 dome pistons Edelbrock heads [Re: Black_Bee] #723780
06/14/10 12:53 PM
06/14/10 12:53 PM
I never had index a set of plugs before ,whitch way are you wanting the tip ,up or down ,as for extended plugs what other option do i have on plugs ,thanks
Re: 383 dome pistons Edelbrock heads [Re: dennismopar73] #723781
06/14/10 02:17 PM
06/14/10 02:17 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
best guess it hit
Mine is the same but with 440-1 heads, I smoothed out the flame trough where the plug points at. not a big deal, and my plugs have never hit.
Re: 383 dome pistons Edelbrock heads [Re: RemCharger] #723782
06/14/10 02:46 PM
06/14/10 02:46 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
What plug did you have in it?
Re: 383 dome pistons Edelbrock heads [Re: abodiesonly1] #723783
06/14/10 05:37 PM
06/14/10 05:37 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Autolite AR3931 plugs, none projected tip.
I've got 440 with JE 12.5.1 domes, 76 cc edelbrock heads.
Mick
