yes,you use the stock v-8 mount/bracket on the driver side( kind that uses the square rubber mount..not a spool)
and any late 70s-mid 80s pass side truck mount
will bolt it right into the /6 k frame in the correct stock location in the engine bay
yes, its a little known racer trick from back in the early days
IIRC you need a 72 or earlier engine bracket that bolts to the block
some one has a pic that get posted every now and then
if i ever see it again I am gonna save that little gem of a pic
and then there are the conversion mounts or change the k-frame
if you change k frame,I suggest a spool mount 73 up myself
watch out for 67 v8 k frames and the funky idler arm also
