{{{{{ 64 VALIANT LEAF SPRING QUESTIONS }}}}}
#721196
06/11/10 11:32 AM
06/11/10 11:32 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
OK, was checking over the new addition yesterday and noticed the leaf springs on the 64 Valiant are marked 62-65 B-Body Pass-side 5-leaf, Driv-side 4-leaf. They have quite an arch to them and the rear sits higher that I'd like, but the shackles are angled perfect and they look to be fairly new...????? I was thinking of flipping the front spring hanger and going with a 2" block....plan is for 15"x 8" Rally Wheels with a 28" MT ET Street Radial P275/60R15 28 X 11.50R15 9.5" Tread 11" Sidewall.....I believe they will fit with the 4.6 backspace without getting into a mini-tub The spring look like my old SS Springs I had on the Challenger, but that was too many years ago Correcting the pinion angle won't be a problem. What do you guys think...run em....????? Rickster
Re: {{{{{ 64 VALIANT LEAF SPRING QUESTIONS }}}}}
[Re: TMP66]
#721198
06/11/10 12:47 PM
06/11/10 12:47 PM
rickstershemi
I'd suggest just move the springs in and get it over with. It's cheap, a piece of cake to do and gives you a boat load of room.
275/60R15 BFG T/A Radial on a 10" wheel. Narrowed 8 3/4, half tub.
First off....Sweet Valiant and sits perfect...
Don't want to tub it and the MT on an 8" rim will give me all I want in tire....more interested in info on these springs...????? Are the early-A and B-Body springs the same spec...???? I wouldn't think so....but want to find out
Rickster
[Re: rickstershemi]
#721199
06/11/10 03:06 PM
06/11/10 03:06 PM
Posts: 302 Casa Grande,Arizona
DennisJ
super street
super street
Casa Grande,Arizona
The A-body front segment is 20 inches.
B-body front segment is 22 inches.
Dennis Jokela
I started out with nothing,and I still have most of it.
[Re: DennisJ]
#721200
06/11/10 03:49 PM
06/11/10 03:49 PM
Dennis Jokela
62-3 B body front spring segment is 20 inches
64-5 B body front segment is 21 inches
66-later B body front segment is 22 inches
#721201
06/11/10 04:39 PM
06/11/10 04:39 PM
rickstershemi
Dennis Jokela
Thanks....haven't measured but they must be 20" as the wheel is centered in the well....I figure they will work and the front segment is very stiff...will flip the front hanger and see where that gets us and then if more is needed toss in a 2" block. From what I'm seeing that should get us close to the ride height we're looking for.
Rickster
[Re: I_bleed_MOPAR]
#721203
06/11/10 04:43 PM
06/11/10 04:43 PM
rickstershemi
Very nice! You guys are killin' me w/ these early As. My first car was a '65 Valiant 2 dr. post w/ a 340/727/8 3/4-3.55 SG. I've been looking for another one for a while but can't find one local (got excited about the one for sale this month but it's in California ). Rick, I hope you post a lot of pics.
No kidding, I had to travel 2700 miles to snag mine
Rickster
Tim
[Re: rickstershemi]
#721204
06/11/10 04:57 PM
06/11/10 04:57 PM
Posts: 20,826 A collage of whims
topside
A collage of whims
Yeah, not only early A sedans, but most of them seem to be white! I want one, too. Should be a part # on the springs, which will let you know the application. IIRC, the front section length did start @ 20", then increase, on the early Bs. The wheel & tire you want to run will pretty much dictate spring location, tub size, and possibly wheel-opening length.
[Re: topside]
#721205
06/11/10 05:02 PM
06/11/10 05:02 PM
rickstershemi
Played around with some wheel measurements yesterday and it looks as if a Wheel Vintiques 15x8 with 4.6 back-space will do the trick....will get better measurements once I get it in the garage.
Rickster
[Re: rickstershemi]
#721206
06/11/10 05:36 PM
06/11/10 05:36 PM
FWIW, here's how 15x7 Cragars fit on my 65 Barracuda, springs in stock location:
