5/16 fuel line for 500 hp?
#719119
06/08/10 01:15 PM
06/08/10 01:15 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
Ill try and explain my senerio.. Im restoring my 71 340 roadrunner for FAST style racing. My Roadrunner was in very original condition with fuel lines in very nice shape, but thay are 5/16. Would this be enough for say a 500 hp 416? 500 hp would probably be on the high end but who knows. any info will be appreciated! -kevin
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
Re: 5/16 fuel line for 500 hp?
[Re: mopars_1]
#719120
06/08/10 01:20 PM
06/08/10 01:20 PM
Posts: 5,080 organ
maximum entropy
organ
i've done it. i've done 600 with 5/16. put a fuel pressure gauge on it.
[Re: mopars_1]
#719122
06/08/10 04:01 PM
06/08/10 04:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I wouldnt stay with the 5/16... go 3/8 or bigger now since you can... do you really think your going to stay with the power you have now... no way
[Re: MR_P_BODY]
#719123
06/08/10 04:10 PM
06/08/10 04:10 PM
Posts: 951 Temperance, MI
prochargedhemi
Temperance, MI
Ive been 10.70's with a 5/16 fuel line and a stock carter pump to boot, though it did go through the traps with 0 fuel pressure
[Re: mopars_1]
#719124
06/08/10 04:35 PM
06/08/10 04:35 PM
MR_P_BODY
Here's why I say you should up grade... first in reality you playing with 1/4" fuel flow.... next in every bend you get 15% reduction unless you have some aftermarket tubes with mandrel bends.... since you can up grade why not... why chance going lean.... JMO
[Re: MR_P_BODY]
#719125
06/08/10 04:50 PM
06/08/10 04:50 PM
Posts: 8,165 Left Coast
BobR
Left Coast
You think like I do, Mike. The one thing that I have noticed in Mopar race sites like this one is the propensity for minimalism. Of course, not everyone is like this-not anywhere near the majority-but there are more Mopar racers this way than all the rest combined. 5/16" fuel line is inadequate for 500 horsepower-especially for racing situations.
[Re: BobR]
#719126
06/08/10 05:04 PM
06/08/10 05:04 PM
MR_P_BODY
I guess that comes from working in the fuel lab for 35 years... LOL
[Re: Jeepmon]
#719129
06/08/10 05:46 PM
06/08/10 05:46 PM
mopars_1
Ridgeland Wi
I will definatly look into this. Im still torn on using my original line or not at this point. also, even if I use a hidden electric pump, would that make a difference? I know FAST allows electric pumps as long as they are hidden. thanks! -kevin Quote:
The only question I have is... Does FAST allow for larger than stock fuel lines?
Somewhere (I'm sure someone will post a link to it) is a chart that shows the amount of fuel needed at HP levels.. and if I can remember, for a 500HP motor, you should be able to deliver 1 gallon of gas in 30 seconds..
With that said, for the first 3 or 4 years, I was running my 525HP motor with stock 5/16 fuel lines and the best volume I was able to obtain was 1 gallon in like 40-45 seconds..
I've since upgraded to a larger fuel line and if FAST allows you, you should upgrade also..
Good luck..
[Re: mopars_1]
#719130
06/08/10 05:51 PM
06/08/10 05:51 PM
Posts: 7,506 Az
Crizila
Az
Go to BG's web sight. They have some info on this topic.
Fastest 300
[Re: mopars_1]
#719131
06/08/10 05:55 PM
06/08/10 05:55 PM
MR_P_BODY
If I recall Dave Dudek was running 3/8 on his.... also I recall the HP cars ran 3/8 lines
[Re: MR_P_BODY]
#719132
06/08/10 06:10 PM
06/08/10 06:10 PM
mopars_1
Ridgeland Wi
hmm i was looking at my fuel line and it looked like 5/16. Ill have to get the drill bit out and find out. I read the rules and you are able to upgrade to 3/8's line
Re: 383man
[Re: sogtx]
#719137
06/09/10 07:00 AM
06/09/10 07:00 AM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
Stay with 5/16" if you HAVE to , but bigger is really better. Well worth the effort to upsize.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
