Re: New Star Vacuum pump installed ! [Re: Bob_Coomer] #718768
06/10/10 01:09 AM
06/10/10 01:09 AM
Arizona
Chris'sBarracuda Offline
Arizona
Is there a good baffle system in the valve cover? I ran a similar setup, and that very same POS Moroso puke tank was horrible. it did very little to seperate the blow by and oil.
be perpaired to do a bunch of cleaning in between rounds with some brake clean and a bunch of rags.
It puked oil every pass, and blowed oil and milky stuff all over the place.
Thing was the POS tank would only have a 3-4 oz in it but would still blow crap every were...
Switched to a Steff;s tank and it was night and day diff...
Good luck.
I fixed that with an inline reservoir tank.. Problem solved..
Chris..
Re: New Star Vacuum pump installed ! #718769
06/10/10 12:01 PM
06/10/10 12:01 PM
Princeton, MN
racingduster Offline
Princeton, MN
HEMIFRED, Do you have any more pics on how you mounted your stuff to your engine plate? lookes like we are using most of the same stuff. I like how you did yours. Its clean.
Thank you
Americans will put up with anything provided it doesn't block traffic. - Dan Rather
