Diameter of steel crank balancer? #716230
06/04/10 08:16 PM
06/04/10 08:16 PM
Northeast, Arkansas
Dodgeman67 Offline OP
Northeast, Arkansas
I need to know the diameter of a '72 and older steel crank harmonic balancer?
Re: Diameter of steel crank balancer? [Re: Dodgeman67] #716231
06/04/10 08:40 PM
06/04/10 08:40 PM
it should be 7.25 for a factory damper.
Re: Diameter of steel crank balancer? #716232
06/04/10 08:47 PM
06/04/10 08:47 PM
Northeast, Arkansas
Northeast, Arkansas
Thanks Dan I appreciate it.
Got a timing tape to put on and don't have one off to measure it by.
The cut spot in the balancer is TDC, right?
The engine is in the car and I got it up on number one as best I could tell and the cut was close.
It's just a .30 over 440 with iron heads.
Re: Diameter of steel crank balancer? [Re: Dodgeman67] #716233
06/04/10 09:19 PM
06/04/10 09:19 PM
yes, the cut in it is TDC. clean the damper real good and then apply the tape. you'll want to clear coat it afterward or you'll likely be picking it up off the floor in about 15 seconds after you start the engine.
