headlite adjustment
#714500
06/02/10 07:33 PM
06/02/10 07:33 PM
dartman366
Mt. Vernon, Ohio
how many of you guy's have replaced the headlite assembly in your car and needed to adjust them for proper alignment? I used to know a trick of using the garage door and shining the beams at it at a certain distance away and the center of the beam was at a certain height from the ground up to the center of the beam,, but I cannot remember those distances,,has antbody here ever done this and can you remember the distance's???
