Re: Electrical Problems
[Re: vjb]
#713290
06/01/10 03:24 PM
06/01/10 03:24 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Give me a minute as I type slow. One possibility is you installed the battery backwards (sounds silly but people do it).
Another is the alternator.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: vjb]
#713294
06/01/10 03:35 PM
06/01/10 03:35 PM
Posts: 2,921 Calgary, Alberta Canada
a12rag
Sounds like a high amperage fault (short circuit) . . . . might want to check the ammeter connections - the one on the dash . . . could be they may have worked loose and are touching ground ??? As was mentioned before, possibly the alternator as well . . . Just my Mark
