Re: 440 camshaft
[Re: bigblockbryan]
#710853
05/29/10 04:15 PM
05/29/10 04:15 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Improper break in, or a tight lifter could be couple causes
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
Re: 440 camshaft
[Re: HealthServices]
#710854
05/29/10 04:16 PM
05/29/10 04:16 PM
Posts: 7,759 So Cal
HealthServices
So Cal
After a couple of flat cams it's cheaper in the long run to just put in a roller cam
Allen
Re: 440 camshaft
[Re: rtman]
#710857
05/29/10 04:30 PM
05/29/10 04:30 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Wiped out a couple over the years (25 plus years 3 or so wiped out) with different cams and motors. I finally figured if you want performance and don't want to fiddle around...
Plus you don't have to wonder if a cam went flat when you have issues. Easier to sell old grinds or have them reground if you don't like them.
Allen
Re: 440 camshaft
[Re: bigblockbryan]
#710859
05/29/10 05:05 PM
05/29/10 05:05 PM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
yea im gonna check the comp out this going a 65 sport fury with a 4 speed was just. Wondering what a good cwould be with 10.1 comp with a 4 speed that i want a nice solid street car
What gear is in it? Kinda depends on how much bottom end your willing to sacrifice for top-end HP. Or vice-versa. I run a Lunati 60303 in a 3.55 4speed cuda, 9.5ish/1 440 and the power band begins at 2000rpm. Gobs of mid range. A smaller cam would be nice for simple cruising, a larger would be nice for heavy throttle fun. Life's a compromise.
BTW--the font end looks really high in that pic. Have you thought about backing off the t-bars?
Re: 440 camshaft
[Re: bigblockbryan]
#710861
05/29/10 05:15 PM
05/29/10 05:15 PM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
I would run the XE275HL in your case. How far down are the pistons in the hole? Yeah and what gear are you running?
Re: 440 camshaft
[Re: ireland383]
#710862
05/29/10 06:21 PM
05/29/10 06:21 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
What is your compression exactly? What pistons? CC of head? Head gasket thickness? Deck height? Most of the recommendations you will get here will be WAY on the conservative side. Lot of naysayers here. Anyway, what gears are you using? Dump that intake in the trash, first of all. Street dominator, M1 or RPM is what Id use. If you want a relatively cheap cam that thumps hard and runs good, stick a Comp 292 in it. Buddy has a 68 Sat with the 292 Comp stick, mild ported 906s, Torker intake,750DP, headers, decent vert, and 3.23s. Low compression, 8.5 to 9 at best, and HIGH miles on the shortblock. Car ran in the 12.30s and he drives it almost every day. If you asked on here if the Comp 292 would work with 3.23s you would get laughed at. As far as wiping a lobe, what valvesprings are you using? What oil did you break it in with?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 440 camshaft
[Re: bigblockbryan]
#710864
05/30/10 01:06 AM
05/30/10 01:06 AM
Von
NE Oklahoma
I'm running 3.23 gears i will not be dumping the intake just bought it awile back so gotta put it to some use i think my heads were 88 cc if i remember right i have speed pro forged pistons that are 10.1 suposably ill have to check the deck height not sure anymore
Id still dump the intake. Basically no better than stock. Sell it on here and get you a good one for probably not any more $$$. You'll end up doing it eventually, might as well do it now.
I bet your comp is closer to 9.5, unless the block has been decked.
Re: 440 camshaft
[Re: 11secondC]
#710866
05/30/10 11:35 AM
05/30/10 11:35 AM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
I like your cam choice, but think you would be better off with a torker II intake or possibly a Holley Street Dominator. Its what I run and really enjoy it. mike
1969 Dodge Dart Swinger
Re: 440 camshaft
[Re: bigblockbryan]
#710867
05/30/10 11:44 AM
05/30/10 11:44 AM
Pacnorthcuda
okay my 440 cam flat spot on a cam lobe why does that happen. it was fresh motor with less then 8oo miles on it it was a mopar performance resto mod cam. my next question is my car has 346 heads 10.1 compression i wanna put a bigger cam in it i liked the resto mod but i wanna little more power this is a street car any suggestions.
What were the specs on the resto-mod cam? Since you have a little experience with THAT cam in YOUR set up use those specs as a baseline. You know you want more cam. 10 degrees additional duration will net a noticeable change in the powerband. 20 degrees is a BIG change. More lift means more flow, to a point, and will make more power. Modern grinds can get you the lift without a bunch more duration.
Re: 440 camshaft
[Re: bigblockbryan]
#710871
06/01/10 03:51 PM
06/01/10 03:51 PM
Posts: 5,161 CT
GTX MATT
CT
20-50 Valvoline VR1 racing oil. You can always run the intake you have and change it later. Its not hard to change after on a big block.
