3.9 litre swap
#70925
06/10/08 01:23 PM
06/10/08 01:23 PM
So I am starting a new project a 64 valiant convertable. Thinking of swapping in a 3.9 litre and 5 speed tranny out of a early nineties Dakota. Most of it should be strait forward. Maybe some mount modifications and header build . Any thoughts on electrical hook up to keep the FI and anyone still make parts for these.Valve covers maybe intakes if I need to get away from the FI.
Re: 3.9 litre swap
#70926
06/10/08 02:15 PM
06/10/08 02:15 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The 5spd trans is fat. Probably the best way to go would be seting the engine forward and keeping the front of the motor in the same place. There are no ears like a SB so custom mounts it is. You might be able to get a front motor plate for a SB and it should work if you don't mind the vibrations. You might have your shifter come out in a weird place so measure this also. You might need to make dog leg shifter. If you just have to have the motor sit back you will need to do major floor surgery. BTW whatever trans fits a SB like an 833OD will bolt right up to the V6 and be easier to fit and find stuff for. This way would be a lot easier in my opinion. For headers get some custome made. Just use the factory EFI with a megasquirt controler, it is supposed to be easy.
Re: 3.9 litre swap
[Re: HotRodDave]
#70927
06/10/08 02:30 PM
06/10/08 02:30 PM
I had thought about the 833 od trans. But I can get a whole 93 Dakota for 1000 to 1500 bucks . They arn't very expensive. With the other sheet metal work I have to do on this reworking the hump will be the least of my worries. I will need to modify it for the shifter anyway. I'm pretty good with metal work. Paint is another story.I have the old 273 that came out of my other car but was going more for fuel economy with the 6 and FI . Any body know what aluminum 833 od tranny and bell housing should sell for? Here is a picture of the car on the trailer As you can see its hurt
Re: 3.9 litre swap
#70928
06/10/08 02:49 PM
06/10/08 02:49 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I thought about doing the same swap but adding a turbo for a Grand National type setup.
The 3.9 should move it just fine but you will need to fab the mounts. Try incorporating the rubber biscuit mounts from the 60s cars into your build.
Re: 3.9 litre swap
[Re: feets]
#70929
06/10/08 03:06 PM
06/10/08 03:06 PM
I already have a elephant ear motor plate for a small block in this car so I may go that route . But would like a little less rattle. Turbo would be fun to play with. But again working the fuel economy gig . With $5.29 a gal for deisel here today my 1 ton isn't very good for parts runs.And my Hardtop is full race anymore so I'm looking for a cruiser that I can have fun with
Re: 3.9 litre swap
[Re: RichV]
#70931
06/10/08 03:45 PM
06/10/08 03:45 PM
DaytonaTurbo
Manitoba, Canada
3.9's are pigs on fuel. Look at the epa ratings, they're only rated at like 1mpg better than the 5.2's when in comparable 2wd dakotas! Trust me, my parents had a 96 dakota, just a plane jane reg cab 2wd truck and it was a pig on gas. No power either. Ran good and all but sucked as much gas as a V8. That v6 dak got about the same mileage as my 74 dart /6 with bad blowby got.
If you're looking for something nice and driveable, you're looking in the right place. If you're looking for something with some decent power and decent fuel economy, you're way way off!
Neither the 5sp nor the auto trans from a dakota is going to fit in your car without some serious floor surgary, just so you know. IMO if you could find and build a 273, you'd probably be able to get the same or better mileage out of it with more power.
Re: 3.9 litre swap
[Re: DaytonaTurbo]
#70932
06/10/08 04:02 PM
06/10/08 04:02 PM
HotRodDave
Kalispell Mt.
The smallest trucks the 3.9 came in was over 4000 lbs. That little a body will knock 1000 lbs off that plus be more aerodynamic. There are a few things you could do to improvwe the mpg over and above that. The injectors have terible targeting and spray pattern, some accel injectors with there cone type spray pattern should help as well as upping the compression and quench. There are a couple ways to do that, you can put in a set of KB 167 pistons and they should be at zero deck with a light deck surfaceing or you can just mill the deck of the block .070 and use the stock flat top pistons, throw in new rings and bearings and your set. Those couple things will help efficency and power a bunch.
Re: 3.9 litre swap
[Re: HotRodDave]
#70933
06/10/08 05:08 PM
06/10/08 05:08 PM
Yes the vert is way lighter than the Dakota. I thought about going with the leaning tower of power and the Aluminum 833 OD tranny. Lots of parts available for them .It would be the easiest but would be less unike. My 273 used to get 17 mpg with 323 posi 8 to 1 compression and the 4bbl cam and 383 AFB on the 273 4bbl manifold with a 727 Automatic and headers. I'm thinking that If I could get up in the high twenties I would have something. Adding FI to the 273 would help and the OD tranny as well but I dont think I can get that much out of the V8. Any one have MPG figures on the new Hemi's. Of course all those cars and trucks are way heavy also.
Re: 3.9 litre swap
#70934
06/10/08 05:22 PM
06/10/08 05:22 PM
HotRodDave
Kalispell Mt.
Don't underestimate a well thought out small block. Read this thread about my 68 cuda. https://board.moparts.org/ubbthreads/show...rue#Post4446182Might take a while but there is a ton of good info in there, not just by me either. A few highlights are a best of 29 mpg on 93 octane and 27 on e-85, both times running 65 mph. I am close enought to haveing my 416 parts together I would just sell the entire engine and trans out of it but oregan is a ways away.
Re: 3.9 litre swap
[Re: HotRodDave]
#70936
06/11/08 10:39 AM
06/11/08 10:39 AM
Yeh out here on the left coast in the 60's when I was just falling in love with cars and Mopars( oh and girls) california was the hotbed of what was happening with hot cars . Now its all on the right coast and it takes months to find out whats happening. LOL Actualy there are alot of cool cars here in Oregon. The magize guys don't pay much attention to this coast though. Thanks for all the info and input. I'll post again when the project is further along. I have a nose job surgery to do first. And start looking and measuring potential components.
Re: 3.9 litre swap
#70939
06/11/08 02:53 PM
06/11/08 02:53 PM
Posts: 4,204 Fort Worth, TX
Clair_Davis
Fort Worth, TX
Buschi340 and I are doing the same trans swap in this thread, so you can go through that and get an idea of what's involved in making that trans fit. FWIW, the AX-15 Dakota trans has a slightly different shifter location, so that MIGHT be a bonus, but it's still a fat unit. As for the V6 vs 273 question, the 273 is only 0.58L or 35ci larger, and has LOTS more potential for upgrades of any kind, plus they grew in those engine bays from the factory. Not wanting to discourage your efforts in doing something different, but strictly from a constructability standpoint, the 273 gets the nod in my book. Now, if you HAVE to do the 3.9, mate it up to an LA bellhousing & trans, bolt it in, and set up the engine mounts off of that assembly. There shouldn't be any issues using the LA bell on the 3.9, and an 833 would bolt right up if the crank is drilled deep enough. Other interesting engines might be the 4.7L OHC jewel (I want to do one of those myself), or even the 3.7L OHC V6. Just try to keep all the factory EFI stuff if possible, and it might be fairly straight forward to install. LA bellhousings will fit both of those, too. Clair
Re: 3.9 litre swap
[Re: Clair_Davis]
#70940
06/11/08 06:47 PM
06/11/08 06:47 PM
feets
Senior Management
Senior Management
Irving, TX
Too bad he can't go with a 3.5 HO from a 300M or LHS. 250 hp and 250 tq would be nice.
Re: 3.9 litre swap
[Re: Clair_Davis]
#70942
06/12/08 01:54 AM
06/12/08 01:54 AM
DaytonaTurbo
Manitoba, Canada
Any idea what the bellhousing bolt pattern looks like on those critters? There are a number of OEM bellhousings out there that can make a pile of interesting swaps possible. What about a Jeep Liberty / TJ 2.4L bell bolted up to a 2.4L SRT-4 engine? 300hp/tq would motivate an early A just fin, and would probalby pull 25-30mpg, too. This again would use the NV1500, Dak AX-15 or Supra R154 trans. I bet weight distribution would be tail-heavy...
Clair
The dakota/jeep 4cyl trans won't survive behind the SRT-4 motor. You'd need to use the supra trans. However there is someone fabbing up adapter plates to put a small block 904/727/500o/d series trans behind a 2.2 or 2.4. If I had an A body I would be so all over that swap. An A-body with a 2.4 would be as light as a lot of the fwd cars, so I bet performance would be great while pushing 30mpg. Only downside is you gotta deal with that ricey 4 banger turbo sound. But worth it IMO.
Re: 3.9 litre swap
[Re: DaytonaTurbo]
#70943
06/12/08 06:55 AM
06/12/08 06:55 AM
Posts: 1,611 Pataskala, Ohio
GTX70sixpack
Pataskala, Ohio
My 98 Dakota weighs 3500# 3.9 % spd, has got a best ever of 22mpg. 318's in B-bodies 20mpg average and 21.5 in my sons 66 Dart wagon when it had a 318. I'm going to do a Passion od conversion on my 65 Belvedere 9 pass. It gets 19.5 now with a automatic.
Gas milage aside, you will have to cut the torsion bar crossmember and floor pans to use the Dakota 5 spd. That was my original plans for the Belvedere but I didn't want to hack it.
Our local pick and pull sells engines complete for $119 and trannies for $55 seems you could get a much better deal than that Dakota. I just bought a nice 1 ton Van that looks and runs great for the 360 Magnum and harnesses for another project for $500. A friend of mine just passed on a $400 Dakota.
65 Belvedere II Station Wagon 69 Coronet R/T convertible 70 GTX 70'cuda 99 Dodge Diesel dually 4X4
Re: 3.9 litre swap
[Re: GTX70sixpack]
#70944
06/12/08 01:30 PM
06/12/08 01:30 PM
Yes I dont have a particular Dakota in mind I've been looking on line and have seen some pretty inexpensive ones . Thats what spurred the thought of buying the whole truck and useing for the parts. And heck the truck could get a 440 or stroker later and make a nice race truck. I realy like the idea of the 5 spd OD but the aluminum 833 OD will probably be the way to go. Either behind the 273 or the V6 or if I sell out completely and go the esiest route /6. The 273 would be the cheapest route as I already have it and its a good runner 318 crank 340 rods trw flat top forged piston. Just need to get rid of the racy cam .Find a new intake and maybe aftermarket FI. Build headers either way
Re: 3.9 litre swap
[Re: Clair_Davis]
#70947
06/19/08 09:46 AM
06/19/08 09:46 AM
Posts: 833 Marietta, GA
Joatha
Marietta, GA
I think some Dakotas came with Mopar 2.5's - not 100% sure on that, but I've seen them transplanted from FWD cars as well. It didn't look too tough, like no elephant ears or anything like that. If you got the trans located, it shouldn't be too tough to get the engine mounts sorted out.
Don't the Jeep Liberty's come with 2.4L engines like are in the PT Cruiser and Neons? Seems like that would be a good place to start as well.
Clair
They did come with them. But, I don't think any of the Liberty (nor the Dakota's) had a turbo. And, I'd think that an A-body would need a turbo 4 to make any power at all. Having said that, you got me thinking that you could use a turbo motor and perhaps cherry pick some parts from a Dakota to get what you need to help make it RWD. Combine that with the tranny adapter to put a 904 behind it and it just might be possible. I'd be lost when it comes to making the mounts, though. I do have a friend that runs a machine shop. If I can fashion up the mounts using cardboard, I'm sure he can make them.
I'd think my biggest issues would be getting the belts, hoses, and linkages (throttle, tranny, etc) worked out.
1966 Barracuda
1968 Barracuda convertible
1930 Ford Model A (soon to be hemi equipped)
2006 Dodge 3500 4X4 CTD Quad Cab
Re: 3.9 litre swap
[Re: Joatha]
#70948
06/19/08 10:44 AM
06/19/08 10:44 AM
Clair_Davis
Fort Worth, TX
...Having said that, you got me thinking that you could use a turbo motor and perhaps cherry pick some parts from a Dakota to get what you need to help make it RWD.
We have a WINNER!! There was a 2.2 T2 early Dakota on ePay a year or three back, and it looked like the biggest problem that guy had was that the throttle body pointed in to the firewall of the Dakota.
...Combine that with the tranny adapter to put a 904 behind it and it just might be possible.
A 904 would certainly be one option, and probably the easiest fit in an early A. It might not be that hard to fit a T5 or some other OD trans to take full advantage of the light-throttle, small-displacement scenario.
...I'd be lost when it comes to making the mounts, though. I do have a friend that runs a machine shop. If I can fashion up the mounts using cardboard, I'm sure he can make them.
The mounts do seem like they'll be a little tricky, but that's mostly because I'm not familiar with how the early Daks handled that. I've only seen one I4 Dak in the salvage yard, and I didn't pay much attention to how the mounts were done that day...
...I'd think my biggest issues would be getting the belts, hoses, and linkages (throttle, tranny, etc) worked out.
Belts would probably just be the typical belts for the engine package. Hoses would be pretty straight-forward as well I think. Throttle/tranny linkage would be cables pirated from the FWD package, and are pretty easy to adapt. I've got a Magnum V8 throttle cable adapted to my 69 Valiant's EFI setup, and all it really took was a small flat file to tweak the gas pedal mount and some flat metal stock to mount the cable.
I think before I spent a lot of time looking at an old 2.2L, I'd investigate the newer 2.4L engine combo. Newer technology, easy 16V availability, still in production, lots of upgrade parts... The 2.4L in 2002 Jeep Liberty had 150hp and 167lb-ft stock. Not bad for an unboosted engine.
Clair
Re: 3.9 litre swap
[Re: Clair_Davis]
#70949
06/19/08 11:14 AM
06/19/08 11:14 AM
DaytonaTurbo
Manitoba, Canada
Only problem would be mounts and linkage. Because remember, if you install a 2.2/2.5 into a rwd application, if it's a T2 motor, the throttle body will point sideways. So while that would not pose a problem for throttle linkage, you would for sure have to use a kickdown cable.
Motor mount would have to be fully custom. I would make semi-functional templates out of wood first, then copy them in steel. But honestly if you don't have a welder, I don't think it's a good idea. I mean you really want to be able to fab some of this stuff up yourself on the fly. But by all means give it a try, it's something I've always wanted to do. The 2.5's do a little better behind an auto trans than the 2.2's, any extra displacement helps in the bottom end. They don't rev nice and high like the 2.2's do though.
IMO a 2.4 is a better choice. 16v, dohc, 150hp stock. I've seen a few dyno sheets from guys on the turbo boards who've built 2.4's, bolt on a hx/hy 35 turbo off a dodge cummins and lay down 450hp at the crank with a good tune, good intercooler and a smack load of boost!
Re: 3.9 litre swap
[Re: Clair_Davis]
#70950
06/19/08 12:12 PM
06/19/08 12:12 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
Clair
...considering my slant 6 is 101hp/199tq stock and it moves my duster pretty good with an A833OD/3.21 rear gear. with the 2.4, I'd jump to a 3.55 or 3.73 rear gear.
Re: 3.9 litre swap
[Re: Clair_Davis]
#70951
06/19/08 12:43 PM
06/19/08 12:43 PM
Joatha
Marietta, GA
Considering I'd use this for a lot of highway friving, I think OD would be a big advantage. Any recommendations on an OD transmission that would fit easily in a 69 cuda? I really don't want to have to cut anything up to put this combo together. Ideally, I'd put the engine transmission in the car and bolt the 904 (or whatever OD) and then build the motor mounts to fit that set up. Ideally, I wouldn't have to change the driveshaft.
Good point on the belts and I can't imagine the throttle linkage would be that bad based on what you sad. Kickdown linkage would just be a Lokar or something like that.
Clair
Well, that's 2 of you that have recommended it. I wonder how hard it would be to add a turbo to it? See below for more questions/comments on the 2.4L.
I can easily make the wood version. I have all the tools for that (plus the expertise). I don't have a welder right now. But, I do have a friend that has one and I'm sure I could borrow it. Then, there's my other buddy with the machine shop....
OK...that's 2 of you that made this suggestion. I'll definitely take a look at it. My dad lives just a few miles down the road from a junkyard out in rural GA and I bet we could get a rebuildable 2.4L core fairly cheap. I'll check out the cummins option on the turbo. I wonder what the best donor car for such an animal would be?
I don't need 450HP. But I would like to get the car up to 200HP and boost the torque a bit. I know that the 318 was rated around 200HP. I wouldn't need a screamer - just enough to allow me to keep up with Atlanta traffic.
I assume I'd need to get the computer as well? Or would I be better off going aftermarket?
Now, the last thing I need is a fargin job to pay for it. Sheesh!
1966 Barracuda
Re: 3.9 litre swap
[Re: Joatha]
#70952
06/19/08 01:51 PM
06/19/08 01:51 PM
DaytonaTurbo
Manitoba, Canada
2.4's are best had out of stratus/sebring/cirrus/breeze, etc. The cloud cars are littered with them. EFI control would have to be aftermarket if you wanted boost. Costs for everything add up seriously fast. Motor build, efi controller, new fuel system, extra $ if you want to convert to turbo, etc etc etc. Everything adds up very quick. If the $ is tight, you are probably better off building a 318 or 273 if you can find one. Fuel mileage will be down considerably, but would leave your other funds open to converting to an o/d 4sp, redoing your rear-end or whatever else. Plus efi and a custom motor install is a lot of work.
Re: 3.9 litre swap
[Re: DaytonaTurbo]
#70953
06/19/08 02:58 PM
06/19/08 02:58 PM
Joatha
Marietta, GA
Yeah, you are right. But what fun would that be?
Once I get a job (and I think I have an offer forthcoming), then I'll be able to afford it. I COULD do it now. But, I want to keep my money in savings until the paychecks start again.
I think if I go the "gas mileage" route in this manner, then I think I'd just get a 2.4L, do quicky rebuild on the motor and transmission, and drop it in there sans turbo. Then, if I need to I can pull it later or add a turbo then. I still have to do a front end rebuild on the cuda and it needs quarters as well (plus paint but that could wait).
Of course, the cheaper/easier route is to just get a Daytona Turbo (or any Shelby vehicle from 84-93) for $2-4K and drive that. I always liked those cars.
Mostly I just have too much time on my hands right now and I like to think about this sort of stuff.
1966 Barracuda
