2004 1500 ram hemi misfire driver side bank
#708996
05/27/10 07:47 AM
05/27/10 07:47 AM
Posts: 7 new york
73 duster
new york
i'm getting rumbling at low rpm.we put a scanner on it<and it came back misfiring cylinders 1357. did a back pressure test on catylic converters <but that came back good.i live in n.y. and go to n.j. once in a while, when i gas up in n.j. the truck stalls 3or 4 tmes after when i come to a stop . it only has 50,000 miles on it. i'm curios if this isproblem is connected. any help?
Re: 2004 1500 ram hemi misfire driver side bank
[Re: 73 duster]
#708999
05/27/10 07:29 PM
05/27/10 07:29 PM
Posts: 163 Winnipeg, MB
sreinheimer
Winnipeg, MB
Is the Throttle housing are gummed up and dirty? Might be a good place to start and clean it to start with.
69 Dodge Charger - first full resto
05 Dodge Magnum R/T
[Re: sreinheimer]
#709000
05/27/10 09:01 PM
05/27/10 09:01 PM
Posts: 7 new york
73 duster
new york
no, itall looks good. the engine light stays on again,but the problem seems to come and go more so then not.i'm the original owner,the truck has been well mantained, and only has 50,000 miles on it.
[Re: Todd]
#709004
05/28/10 07:22 PM
05/28/10 07:22 PM
Posts: 3,023 NY
B1duster
NY
Be carefull. a friend of mines durango started running a little rough and a couple days later it backfired on startup and bent a connecting rod on # 1 cyl. Turns out injector leaked down over night causing the cyl to hydraulic.
[Re: Kern Dog]
#709009
05/31/10 08:49 AM
05/31/10 08:49 AM
Posts: 21,449 It's a dry heat
gtx6970
It's a dry heat
Right, it didn't. The tech at the dealership said that the engine was designed with this feature built in, but it wasn't implemented until the 2006 model. My point was that the lifter was MY problem. My valvesprings were okay, unlike earlier year 5.7 motors.
correct . MDS was not avail on trucks 'till 2006 model year. But as mentioned the block was equipped for it though, it just had normal non-mds lifters and no mds wiring or pcm controls
