Indy 360-2 which arp studs #708993
05/27/10 05:04 AM
05/27/10 05:04 AM
Sydney, Australia
tuff440 Offline OP
tuff440  Offline OP
Sydney, Australia
Does anybody know what the part number is for arp head studs to suit Indy 360-2 heads. I have a set of 144 4001's which I was going to use on some 340 x heads. Will they work with the Indy heads. The arp website does not show anything for Indy heads.Thanks
Re: Indy 360-2 which arp studs [Re: tuff440] #708994
05/27/10 06:43 AM
05/27/10 06:43 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
i think the same kit for the eddies fit the 360 indy heads.
Re: Indy 360-2 which arp studs [Re: tuff440] #708995
05/27/10 06:47 PM
05/27/10 06:47 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Indy heads are the same as W2, I believe you only need to change a couple of bolts to make your existing kit work. You will need a couple of 12 point nuts also. Matt
