Shaker on a 6.1 Hemi Cuda
#708636
05/26/10 06:31 PM
05/26/10 06:31 PM
Posts: 375 Canada
DmanSRT71
Canada
Pretty limited audience for this question, but I'll ask anyway. Has anyone done or seen a Cuda with a Shaker Hood and bubble on a 6.1 hemi using the stock 6.1 intake manifold?
Curious if there was a routing for ducting that looked good and functioned. I really don't know how much room is left above the engine on a 6.1 setup, but I'm guessing it wouldn't fit .
Thanks Darren
69 Road Runner 383/auto/N96
71 Demon 340/4 spd
Would like to find a rust free Cuda body.
Re: Shaker on a 6.1 Hemi Cuda
[Re: gygeneral]
#708639
05/26/10 06:36 PM
05/26/10 06:36 PM
Posts: 375 Canada
DmanSRT71
Canada
That was a quick answer. I'll check with him. thanks *edit* to both of you.
71 Demon 340/4 spd
[Re: johnscudashop]
#708643
12/16/10 07:13 PM
12/16/10 07:13 PM
Posts: 375 Canada
DmanSRT71
Canada
So let me get this 100% straight. You're using the 70-71 bubble. The Danko base, and making them work together? That's what I was after.
71 Demon 340/4 spd
[Re: MuuMuu101]
#708645
12/16/10 08:41 PM
12/16/10 08:41 PM
Posts: 375 Canada
DmanSRT71
Canada
I remember the car. Thanks for the link. I don't remember seeing the engine on the show.... Quote:
I have on Bullrun. Team Hemi Cuda. I believe used a non functional shaker. Here is there website:
http://www.teamhemicuda.com/
71 Demon 340/4 spd
[Re: DmanSRT71]
#708646
12/16/10 08:43 PM
12/16/10 08:43 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
They never showed the engine and wouldn't give any specs on it except for "Horsepower: A Lot" but I saw there audition video and it is fuel injected and makes 475 Horsepower.
[Re: johnscudashop]
#708649
12/16/10 10:53 PM
12/16/10 10:53 PM
Posts: 375 Canada
DmanSRT71
Canada
cut in half, horizontally? As in: made 2" higher with the section? I can handle the F/G or C/F insert no troubles..... Quote:
yes I believe it can be done. But there is going to be some fibergass work on the danko base plate. From what I understand that the baseplate will need to be cut in half and a 2" section made of fiberglass put in. The mounting holes will be off so they will need to be relocated. Also the hieght will need to be adjusted.
71 Demon 340/4 spd
[Re: DmanSRT71]
#708653
12/17/10 10:11 AM
12/17/10 10:11 AM
Posts: 21,405 It's a dry heat
gtx6970
It's a dry heat
While that's an awesome car, I'm pretty sure they used the XV intake, not the factory one. That opens up pretty much stock setups.
could be, the hood was down when I saw it the parking lot
