Power steering gear box question #708392
05/26/10 03:07 PM
05/26/10 03:07 PM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
I have change seal on my AAR TA power steering gear box and found out that the cross shaft diameter is large 1 1/4 inch .I know the TA gearbox had different ratio but had it also larger lower pitman shaft? In the manuel barracudas had 1 1/8 inch in 1970.
Re: Power steering gear box question [Re: AAR70] #708393
05/26/10 09:46 PM
05/26/10 09:46 PM
Stow,Ohio
RBSat66 Offline
RBSat66  Offline
Stow,Ohio
I have been researching gearboxes for my B-Body and found out that up to 1972 they used the smaller pitman shaft and 1973 to 74 used the larger pitman shaft. Hope that helps.
