Re: 440 source stealth heads vs. OEM: Cosmetic differences?
[Re: Azzkikrcuda]
#708193
05/26/10 01:44 PM
05/26/10 01:44 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
IIRC the stealths don't have freeze plugs in the ends either.
[Re: patrick]
#708194
05/26/10 02:25 PM
05/26/10 02:25 PM
Posts: 741 Carson City, NV
440sourcedotcom
Carson City, NV
The ends look completely stock, including the freeze plugs. Here are a couple pictures of the ends and heat riser area:
[Re: domingo]
#708195
05/26/10 02:30 PM
05/26/10 02:30 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
They'll work great.I painted mine black and the filled heat riser passage isn't noticable.
[Re: Chris2581]
#708196
05/26/10 03:05 PM
05/26/10 03:05 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
That head looks dramatically different than a 906/346 head. It looks more like a 452. IMO it shouldn't be used on a car like a V code Cuda. And some of you guys need to get your eyes checked if you think the lack of the exhaust heat crossover is "not noticeable". MB
[Re: HPMike]
#708197
05/26/10 03:57 PM
05/26/10 03:57 PM
DaytonaTurbo
Manitoba, Canada
MB
I think you need a bit of a reality check. An edelbrock rpm head looks dramatically different than a 906 head sure, but the stealth heads are close enough that the casual observer isn't going to notice. However the nit-pickers who are looking to find something wrong will notice. But for the record, all the stock parts and accessories will bolt right up to them. Once the motor's fully assembled and in the car it will look close enough to stock that 99% of mopar guys would not notice the difference unless it was pointed out to them.
[Re: DaytonaTurbo]
#708198
05/26/10 04:33 PM
05/26/10 04:33 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
MB
Thank you for your concern, but no reality check needed here. I am not a nit picker and my vision isn't as good as it used to be, but I can spot those easily on any casual inspection-painted or not. And so can anyone that I know, so Would Joe Blow know the difference?NO. The important thing is that YOU are satisfied with them.
No way I would be putting them on any of my stuff.
MB
[Re: HPMike]
#708199
05/26/10 05:45 PM
05/26/10 05:45 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
MB
MB
I know that the differences will be apparent, if compared one beside the other...
But if they are small enough I guess it wouldnt hurt to have aluminum heads on ana otherwise all stock looking engine...Id hate to dump $$ on old 906 castings when I can buy brand new heads for $900 bucks that will overpower the 906 heads, not to mention offer weight savings. Also, its not a permanent mod....so I dont feel guilty about doing it...or using new H beam rods, or an updated hydraulic cam grind...we'll see...
[Re: domingo]
#708203
05/27/10 12:24 PM
05/27/10 12:24 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Your 71 wouldn't have 906 heads - it would have the next series head (346?) and those have two noticable vertivle casting lines at the end.
However - I'm with Mike - it's your car, do what you want! Be happy with it.
[Re: 70RT Charger]
#708205
05/27/10 02:36 PM
05/27/10 02:36 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
He's right, I'll give you 25 cents for each dollar you spent on the 440 source heads and stroker kit. PM me for my address.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#708206
05/28/10 08:58 PM
05/28/10 08:58 PM
Posts: 6,085 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
I think they resemble the 906s more than the 346s or 452s. 906: 346: 452:
[Re: Commando1]
#708208
05/29/10 06:35 PM
05/29/10 06:35 PM
All aftermarket heads come from China so they all look alike.
Slanted?
