DYNOJET DYNO RESULTS FROM JAKES-ADDED VIDEO LINK
#707835
05/25/10 11:26 PM
05/25/10 11:26 PM
Posts: 2,325 Clinton Twp... north of Deetro...
Labratt
Good Ol Randy B!
Good Ol Randy B!
Had a good experience hangin' out at Jake's Auto today,gettin' the GTX dyno-tuned! If the correction factor they have is correct,I'm pretty happy with the results! 1st pull(baseline)resulted in 412hp @ 6,000 Rpm. Tq. was 392 @ 5200 rpm. After several pulls,and jet changes,and 1 timing change,going from 37 to 39,the best numbers were 422hp @ 6,000 and 408tq. @ 5200rpm. Jetting started out at 82p and 90sec. With "best" results,they were 82Pri. and 81sec. To me that is pretty strange,since I'm running a PV in the primaries! Also swapped the 850 Holley to a Pro Systems Holley 1000cfm. It made 422hp @ 5900rpm and 411 tq. @ 5200, but with a A/F ratio of 7.99! Sounds like with a GOOD a/f on the bigger carb,my little 448 would pick up some extra HP and TQ! Had a lot of fun doing this,and I actually got to turn a couple of wrenches,and get my hands dirty! Forgot to mention,the ambient temperature was 83-84 degrees,and 40 humidity. Pretty warm! I'd like to thank Gary Jacob,his son Chris,Tim,and Steve,who operated the dyno,and made the adjustments. Thanks guys! BTW... with their RWHP divided by .72 formula,the hp at the crank comes out to 586! Thanks for taking the time to read this! RandyB. One more little thing I forgot to mention,the engine made 3-4 more hp with my K&N filter and X-Treme top on!
Re: DYNOJET DYNO RESULTS FROM JAKES!
[Re: Labratt]
#707838
05/26/10 12:05 AM
05/26/10 12:05 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Were you using my carb for your best out put EDIT Who had the 1000 cfm carb... was that a 4150 base
[Re: 340RICK]
#707843
05/26/10 07:49 AM
05/26/10 07:49 AM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Congrats Randy,
Any video of the car ?,,,, way cool to see it strapped down,,,screaming away on the dyno...
Cant wait to hear a track report.
Doug
[Re: Dartin]
#707847
05/26/10 09:12 AM
05/26/10 09:12 AM
Labratt
Good Ol Randy B!
Good Ol Randy B!
Thanks fella's! Rick,I hear ya,I had a blast,especially with the fact that I actually turned some wrenches and got my hands dirty! Steve(dyno operator)was surprised the power picked up by advancing the timing from 37 baseline to 39,where we left it. Larry,I was running 93 pump gas,only 10.25 compression. I put a video of one of the last runs on U-Tube. Go to RandyB's 440,click on the drag strip video,then click the 3 videos icon,and it will come up. Not sure why it didn't show with my other videos??? Thanks again for your supportive comments,I appreciate it! RandyB
[Re: Labratt]
#707850
05/26/10 11:13 AM
05/26/10 11:13 AM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
Way cool Randy, glad to hear you're happy with it I don't know about that HP divided by .72 formula, it seems to give too high a flywheel hp number (499 wheel, 693 flywheel on mine...it isn't making that) but that's a minor pickin' point...it doesn't mean much in the big picture.
Rich H.
Esse Quam Videri
