What is the typical life expectancy of shock absorbers? #70681
06/09/08 10:47 PM
06/09/08 10:47 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Just curious as to what the typical life expectancy is of shock absorbers on modern day cars. I know a lot of it would depend on how much abuse they are subjected to but just assuming they are only exposed to average daily driving with no extraordinary punishment, what would be a realistic lifespan to expect from shock absorbers, particularly the shocks installed at the factory?
Re: What is the typical life expectancy of shock absorbers? [Re: 6PAX] #70682
06/09/08 10:52 PM
06/09/08 10:52 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Most cars run 'struts' all around, mostly only trucks still run a shock absorber of some sort..Same idea however, last car we had was a '00 taurus, 86,000 on the factory stuts..were holding up fine. But I have seen cars from up north with 40,000 and you could get motion sick driving (VW).
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: What is the typical life expectancy of shock absorbers? [Re: 6PAX] #70683
06/10/08 08:04 PM
06/10/08 08:04 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I am flat out amazed that the Edelbrock IAS shocks on my 1995 Ram 4x2 have lasted over 120,000 miles and still work pretty well. The red powder coat is still in good shape too.
Re: What is the typical life expectancy of shock absorbers? [Re: 6PAX] #70684
06/10/08 09:33 PM
06/10/08 09:33 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I changed mine out when they were 41 years old.
Sheldon
Re: What is the typical life expectancy of shock absorbers? [Re: 6PAX] #70685
06/10/08 10:07 PM
06/10/08 10:07 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
I think I remember reading some shock industry material that suggested replacing parts in the 25-40K mile range. I've had some Gabriel Terrain-Tamer shocks last well over 60K miles and have plenty of pressure and damping left in them. I've also had OEM replacement (read: Mopar from the dealer) struts last MAYBE 10K miles before they were outright flacid. Same can be said for some Bilstein HD struts that replaced the Mopar units... maybe 20K out of them tops. It's not just Mopar parts that suffer, either. I have a set of OEM shocks/struts from a relatively low-mileage 2008 Honda Fit, and the damping is inconsistent between the pairs already. KYB supplies thes shocks/struts.
In the end, you may get lucky and get a bunch of miles out of a set, but you really have to keep your eye on them and stay tuned in to how they're working. Unless they die a tragic death, you may just get used to the gradual decrease in performance and one day you realize you're driving a wallowing pig...
Clair
Re: What is the typical life expectancy of shock absorbers? [Re: Clair_Davis] #70686
06/10/08 10:23 PM
06/10/08 10:23 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
so...? 200K is too much? dan
Re: What is the typical life expectancy of shock absorbers? [Re: ph23vo] #70687
06/10/08 10:37 PM
06/10/08 10:37 PM
Kirkland, Washington
Pacnorthcuda Offline
ask an autocrosser this question!
Re: What is the typical life expectancy of shock absorb [Re: Pacnorthcuda] #70688
06/11/08 06:40 PM
06/11/08 06:40 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Yes this is the answer.
Really it depends on your driving style, the car and your expectations from the new shocks.
Before my LHS came out of warranty I had them throw some struts on it. It wasn't due but it sure looked like it after a couple shots from my oil can. Anyways the car seemed to drive the same and comfort was the same but there was this one curved on ramp I use often. A bump used to make the car skip over. With the new struts it would follow the curve and ignore the bump.
Light cars with stiff springs. Will tend to not show a worn shock as early as a heavy car with soft springs.
