I want to install a 3/8 fuel line from my fuel tank to the stock fuel pump and a 5/16 return line back to the tank. Where up front do I plumb the 5/16 return line into the fuel system. And where in the tank does the return line plug into? I have a '69 383 that had a stock 5/16 fuel line setup but I want to install the larger 3/8's line with the 5/16 return line for future horse power growth. Can I order off the shelf lines for a '69 Plymouth B-body 440 or Hemi? I know I need a 3/8 sending unit as well. Any advise is much appreciated.
