Jeep Engine Control Module #704957
05/22/10 12:48 PM
05/22/10 12:48 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I have a friend who has this shredded Engine control. He has a Mod-Jeep and his 84 CJ has a 93 YJ 4.0 motor. His mechanic said that the EC is burned out. If he wanted (which I know I would be doing it) could he cut away that epoxy junk on top, hit it with a hair dryer and melt the rest away, find the burned out components with spares from Digi-Key, and then get it back into service? They want upwards of $75 to service this. But the parts probably cost $1.00...
If he does the service himself, where do we get the epoxy to melt back into the module?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Jeep Engine Control Module [Re: Pyper70] #704958
05/22/10 06:54 PM
05/22/10 06:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I tried that on one and nothing short of picking the stuff out seemed to work includeing the hair dryer that just made tons of stinky smoke like you wouldn't beleive. I ended up useing a razor blade and exacto knife to remove the majority and tooth picks and finger nails to get it off the components and when I was done I could not find the right parts (alternative parts may have been useable but I don't know that much about electronics to try different pieces). Mine had a problem with charging my battery properly and I ended up getting a computer from a JY for $20.
