440 crank ID?
#70433
06/09/08 01:24 PM
06/09/08 01:24 PM
Posts: 4,722 Moved to N.E. Tennessee
GomangoCuda
I have come across a "67" 440 that has some mixed parts. The Dampener is for a forged internal balance engine as it should be in "67" but the flywheel is the externally balanced item used with the "70" and up 6pk style rods. My first thought is to put a neutral balance flywheel on it but who knows maybe the rotating assembly is from a later engine and the balancer is the part that is wrong. So, do I have to pull the pan to know for sure or is there a dead giveaway in the shape of the crank flange perhaps? Thanks
Re: 440 crank ID?
[Re: dogdays]
#70435
06/09/08 04:09 PM
06/09/08 04:09 PM
Posts: 3,449 Gateway to the West.
hemi_harvester
IS the crank drilled for a pilot bearing? IF its not drilled it could be a cast crank also, which is exterally balanced too.
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: 440 crank ID?
[Re: GomangoCuda]
#70440
06/10/08 01:36 PM
06/10/08 01:36 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
see the new england cruise thread and the pics of kudakids duster BEFORE installing that pan
Yea, I haven't even looked yet but I know what I am going to see. That's the reason I didn't put it on a long time ago. I wish the Ebody hemi pan wasn't made out of gold. Over $200 for a repro pan and pickup seems a bit excessive when they sell the cheap (chinese?)deep pans for less than $50. I would even buy a well used pan if I could find one. I don't need perfect, just functional.
what pan is currently on your engine ? i have a couple of slightly used ones i'm looking to trade
