Re: How Does This 440 Build Sound? [Re: bordin34] #702517
05/22/10 01:45 PM
05/22/10 01:45 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
They should work fine.
Nautilus Racing-
Re: How Does This 440 Build Sound? [Re: bordin34] #702518
05/22/10 09:27 PM
05/22/10 09:27 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Thanks, I think I'll stick with a normal head gasket for now.
Does anybody know if the stock Stealth springs will work with the 60303 cam?
I run the 60303 with stock stealth head springs. No problems.
Re: How Does This 440 Build Sound? [Re: DaytonaTurbo] #702519
05/23/10 12:08 AM
05/23/10 12:08 AM
West Coast, Canada
Dakota542 Offline
Dakota542  Offline
West Coast, Canada
If the budget is tight, consider building a really good short block (with good pistons and rings). You can always run a stock cast head until more money allows for aluminum.
Heads are easy to change - pistons not so much.
Re: How Does This 440 Build Sound? [Re: Dakota542] #702520
05/23/10 09:42 AM
05/23/10 09:42 AM
Central NC
gch Offline
gch  Offline
Central NC
Rather than gamble on the steel shim head gasket with alum heads I would have the heads milled(intake side as well)to get the compression up some and run a good composition gasket.
The 750 vacuum secondary gets my vote as you have a heavy car.You could mill the choke horn for a few extra cfm if need be.
3.23 gears and an 11" converter will smoke the hides at will and cruise effortlessly.
I had a 73 charger for 10 years and it was way more fun driving it everywhere when it ran low 13's than it was with a built motor,big stall and 4.10 gears.12.0 is fun but the constant rpm buzz,terrible mileage,and loud everything made it into a weekend short trip car.
Re: How Does This 440 Build Sound? [Re: gch] #702521
06/02/10 09:51 PM
06/02/10 09:51 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
I have a question about bearings. I have a '76 block with the larger thrust bearing cut-out thing. I ordered the bearings and noticed that the ones I bought came with the earlier style thrust bearing. Would it be worth it to order a set with the later style bearing or even swap in the thrust bearing from when the engine was assembled before but never run that is from a different company?
Re: How Does This 440 Build Sound? [Re: bordin34] #702522
06/02/10 09:56 PM
06/02/10 09:56 PM
NJ
440challenger Offline
NJ
that summit 488 cam is great . I have it in my smogger 440 and the car pulls HARD for a super mild low compression motor
Re: How Does This 440 Build Sound? [Re: bordin34] #702523
06/02/10 10:07 PM
06/02/10 10:07 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
There are hundreds of thousands of engines out there using the "old" style bearing. Don't waste the time or effort to get the new style.
