Thermal fan clutch #700497
05/17/10 01:56 PM
05/17/10 01:56 PM
Palm Springs, Ca.
mopar71 Offline OP
mopar71  Offline OP
Palm Springs, Ca.
How do you test for a good/bad thermal fan. I suspect it cause it starts to get hot at idle only. Want to make sure this might be the problem.
Re: Thermal fan clutch [Re: mopar71] #700498
05/17/10 03:28 PM
05/17/10 03:28 PM
get it good and hot, shut eng off and spin it by hand & is should have a fair amt of resistance. EDIT was it Ok then started acting up w no other changes?
