Re: 30 plymouth , sway bar help? leans bad in turns
[Re: RodStRace]
#700294
05/21/10 11:33 PM
05/21/10 11:33 PM
Posts: 1,757 levittown pa
fstfish66
levittown pa
fat mans sway bars are made by compitition engineering if i rememebr correctly,, comp could care less about mopars,,,, fat man has a page with drawlings and deminsions on sway bars,,, i used it when fitting a rear bar to my 40 dodge,,,ended up using one from a late 30s chevy,,that pictured late 40s ford rear shock set up that was exactly the same as my 40 dodge rear shock set up,,the bar fat man wanted me to use was a universal and wouldnt clear my already finished exhaust..
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: fstfish66]
#700295
05/28/10 01:46 AM
05/28/10 01:46 AM
Posts: 1,294 Under the big sky
stateline
Under the big sky
I used one off the rear of a late 90s Ford Explorer, I used the axle mounting brackets from a Bronco 2, Ranger PU brackets work too, The 1953 Hudson I put it on is pretty narrow in the rear, you might check and see if the Explorer one is close- pic attached
[Re: stateline]
#700296
05/28/10 01:49 AM
05/28/10 01:49 AM
fstfish66
levittown pa
I used one off the rear of a late 90s Ford Explorer, I used the axle mounting brackets from a Bronco two, Ranger PU brackets work too, The 1953 Hudson I put it on is pretty narrow in the rear, you might check and see if the Explorer one is close- pic attached
nice looking conversion,,,the upper shock mounts stock location or did you have to modify alll that for the upp sway bar links??
[Re: fstfish66]
#700299
05/28/10 02:28 PM
05/28/10 02:28 PM
stateline
Under the big sky
Lucked out on that one , just used longer bolts on the upper shock mounts
[Re: stateline]
#700300
05/29/10 12:08 AM
05/29/10 12:08 AM
fstfish66
levittown pa
my 40 dodge is set up like that using the upper shock mount for the sway bar link,,all tho i had new heavy upper mounting studs machined to accept every thing,,looks like u have a nice set up there
[Re: dirt]
#700302
08/03/10 09:21 AM
08/03/10 09:21 AM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
Have you got a part number or link for the sway bar? Need one on the 36. Thanks!
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
[Re: 36PLYM]
#700304
08/04/10 02:23 AM
08/04/10 02:23 AM
fstfish66
levittown pa
they have several to choose from,,a lot depends on the lay out under your car,shocks/exhaust/frame or axel width/
i used one designed for a 37 chevy on my 40 dodge, its the same bar fat man uses on 46 47 48 fords, the bar i used mounts under the axel and the links go to a stud i had made that doubles as the upper shock mount and upper sway bar link mount,, the sway bar wraps around the lower shock mounting and ends up as wide as the inside deminsion of my frame rails,,shaped like a U with a hook on each end,, car is in storage so no pics ,,hope to have it back in my garage end of sept,,,
