Where to install vacuum pump fitting on valve cover ?? #699446
05/16/10 11:06 AM
05/16/10 11:06 AM
Saskatchewan, Canada
cudabin Offline OP
cudabin  Offline OP
Just ordered a new Star vacuum pump and wondering where you guys mount your fittings on the valve cover?
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Where to install vacuum pump fitting on valve cover ?? [Re: cudabin] #699447
05/16/10 01:23 PM
05/16/10 01:23 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Re: Where to install vacuum pump fitting on valve cover ?? [Re: cudabin] #699448
05/16/10 06:30 PM
05/16/10 06:30 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Re: Where to install vacuum pump fitting on valve cover ?? [Re: cudabin] #699449
05/17/10 06:54 AM
05/17/10 06:54 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Target the rocker hold-down area...mimic the factory breather location.
Re: Where to install vacuum pump fitting on valve cover ?? [Re: HardcoreB] #699450
05/17/10 08:58 AM
05/17/10 08:58 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Me, I'd put it towards the front of the motor, opposite bank as the breather, to get some crossflow, and a baffleplate inside of the valvecover to dampen the direct pull of windage near it. If you're running a breather on each valvecover, I'd try to put a vacuum pump fitting at the opposite end of each valve cover.
Re: Where to install vacuum pump fitting on valve cover ?? [Re: cudabin] #699451
05/17/10 09:13 AM
05/17/10 09:13 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO you are gonna need to install it in the center of the valve cover toward the intake. Use the Star baffle and put it dead center on the center rocker hold down. Trust me we tried it a few places and this was the best location that picked up the least oil.
You can see mine on the drivers side cover, as well as the other places we have tried here.
Re: Where to install vacuum pump fitting on valve cover ?? [Re: HardcoreB] #699452
05/17/10 09:19 AM
05/17/10 09:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
This is pretty much the way I do it... over top of
the wide rocker shaft hold down towards the front of
the cover... that area gets the least amount of oil
Re: Where to install vacuum pump fitting on valve cover ?? [Re: Ari440] #699453
05/18/10 11:09 AM
05/18/10 11:09 AM
cudabin Offline OP
cudabin  Offline OP
Ari440, How much oil do you get in the puke tank after a run with the fitting on top?
I have a baffle under the breather hole in the same location as Ari on my Indy valve covers, so I will try that first before drilling new holes...
Thanks,
Arnie
Re: Where to install vacuum pump fitting on valve cover ?? [Re: cudabin] #699454
05/18/10 04:45 PM
05/18/10 04:45 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Thanks,
I get less then 1/4 of oil in the tank
my regulater is setup at 12 pounds of vacume
I have no baffle in the valve cover but use the a fitting thats drilled holes all around it
also im useing regluar molley rings 1/16
1.39 9.85 - 137 mph
Re: Where to install vacuum pump fitting on valve cover ?? [Re: Ari440] #699455
05/18/10 06:51 PM
05/18/10 06:51 PM
cudabin Offline OP
cudabin  Offline OP
Ari440,
Do you mean 1/4 of the tank per pass? how big is the puke tank??
Thanks,
Arnie
Re: Where to install vacuum pump fitting on valve cover ?? [Re: cudabin] #699456
05/18/10 06:59 PM
05/18/10 06:59 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
woody how did you fasten down that carb screen. thx
Mopar Performance
Re: Where to install vacuum pump fitting on valve cover ?? [Re: cudabin] #699457
05/18/10 07:35 PM
05/18/10 07:35 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
its a small tank
at E TOWN I get about two passes and im done for the day
I got a long way to go home
1.39 9.85 - 137 mph
Re: Where to install vacuum pump fitting on valve cover ?? [Re: Ari440] #699458
05/18/10 08:58 PM
05/18/10 08:58 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW I get maybe a 1/2 ounce per pass of milky mix.
Re: Where to install vacuum pump fitting on valve cover [Re: cudabin] #699459
05/18/10 09:42 PM
05/18/10 09:42 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
When are you going to make a pass with all those new parts on the Cuda ? was perfect weather for the season opener in Medicine Hat last weekend ! Car should work great l look forward to a hearing about your progress.
76 Duster work in progress
Re: Where to install vacuum pump fitting on valve cover [Re: Edge] #699460
05/18/10 11:51 PM
05/18/10 11:51 PM
cudabin Offline OP
cudabin  Offline OP
Hi Edge,
I pick up the Star vacuum pump kit on May 27th and will install that weekend to be ready to rock the first weekend in June!!!
That is if I get the motor in and everything else hooked up by then.
I made 900HP after all but it needed the vacuum pump to seal the rings...
I am going to try it like Ari has it and see what happens.
Cheers,
Arnie
Re: Where to install vacuum pump fitting on valve cover ?? [Re: moparniac] #699461
05/19/10 01:21 AM
05/19/10 01:21 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I never got around to that...I just place it on there when I have the hood off...keeps the bugs out..
Re: Where to install vacuum pump fitting on valve cover [Re: cudabin] #699462
05/19/10 11:36 AM
05/19/10 11:36 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Arnie
whats your combo for 900 hp
if you dont mind
1.39 9.85 - 137 mph
Re: Where to install vacuum pump fitting on valve cover [Re: Ari440] #699463
05/19/10 12:51 PM
05/19/10 12:51 PM
cudabin Offline OP
cudabin  Offline OP
Arnie
if you dont mind
Here is the thread from my dyno time with combo listed:
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Cheers,
Arnie
Re: Where to install vacuum pump fitting on valve cover [Re: cudabin] #699464
08/09/10 12:04 AM
08/09/10 12:04 AM
cudabin Offline OP
cudabin  Offline OP
well I need to try a different pick up location, as it is pulling 10 ounces out in a 1/4 pass and the Moroso puke tank is blowing oil out the breather making a mess...
Going to try it in the front face of the VC like Woody has his.
My Injected methanol motor is making some serious power, but the oil hassle needs to go!!!
Any other ideas?
Re: Where to install vacuum pump fitting on valve cover ?? [Re: cudabin] #699465
08/09/10 12:12 AM
08/09/10 12:12 AM
iowa
wesw Offline
wesw  Offline
iowa
from the front of the valve cover.
598 ci predator
Re: Where to install vacuum pump fitting on valve cover ?? [Re: wesw] #699466
08/09/10 09:56 AM
08/09/10 09:56 AM
cudabin Offline OP
cudabin  Offline OP
Thanks WESW,
I notice you have it closer to the intake on the front of the Valve Cover, than the exhaust. Any logic to that?
I have the Star fitting that is open on one side only. I am assuming it should face down for the opening??
Thanks,
Arnie
Re: Where to install vacuum pump fitting on valve cover ?? [Re: cudabin] #699467
08/09/10 10:15 AM
08/09/10 10:15 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
you may also want to weld in a bung for a vacuum gauge like i have...
Re: Where to install vacuum pump fitting on valve cover ?? [Re: cudabin] #699468
08/09/10 10:45 AM
08/09/10 10:45 AM
New York
polyspheric Offline
polyspheric  Offline
New York
where you guys mount your fittings is less important than how effective the baffle is. It must completely obscure (mask) the opening from line-of-sight, and not drain into the aperture path. If there's room, a labyrinth is better.
Boffin Emeritus
Re: Where to install vacuum pump fitting on valve cover ?? [Re: polyspheric] #699469
08/09/10 11:33 AM
08/09/10 11:33 AM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I am pulling vacuum from a moroso breather AND I have a full size baffle under it as well. I hope this works (I think it will).
SRT DEMON ONE SEAT
Re: Where to install vacuum pump fitting on valve cover ?? [Re: cudabin] #699470
08/09/10 12:05 PM
08/09/10 12:05 PM
iowa
wesw Offline
wesw  Offline
iowa
Thanks WESW,
Thanks,
Arnie
it does face down. it pulls from the bottom of it inside the valve cover. my vaccum line for the gauge and racepak is on the back side of the other valve cover.
598 ci predator
Re: Where to install vacuum pump fitting on valve cover ?? [Re: wesw] #699471
08/09/10 12:24 PM
08/09/10 12:24 PM
oregon
greendart408 Offline
oregon
I have the star pump and tank on my injected alky sb. I installed the pickup in the very front of my valve cover as per stars instructions and even with the topend restricted it would fill the tank and pump with oil every pass. With the star pump you cant have ANY oil in the pump or it wont pull vacuum. I just last weekend installed the pickup over the second large rocker holdown at the front of the motor and this solved the issue all together for me.
Re: Where to install vacuum pump fitting on valve cover ?? [Re: greendart408] #699472
08/09/10 11:19 PM
08/09/10 11:19 PM
cudabin Offline OP
cudabin  Offline OP
I am running individual shaft mount Jesel Pro rockers with pushrod oiling, so maybe thats why the top of the vc is not working for me?
If the Star pump does not pull vacuum with oil in it, then why does mine continue to pull oil into the tank every run?
Please educate me as this is driving me nuts cleaning oil off the motor every pass...
Thanks,
Arnie
Re: Where to install vacuum pump fitting on valve cover ?? [Re: cudabin] #699473
08/09/10 11:37 PM
08/09/10 11:37 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
I took my vacuum pump off years ago and kicked a field goal with it ,, never again.
I built a puke tank that never slobbers or even gives off a the slightest bit of oil vapor.
Get your car to 180 and don't bother with the messy vac pump.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Where to install vacuum pump fitting on valve cover ?? [Re: cudabin] #699474
08/10/10 12:11 AM
08/10/10 12:11 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Thanks,
Arnie
are you using the Star tank?
and Star fitting ?
if not the pump is not being used properly. STAR does not even stand behind the pump when used witout the cannister. That pump is to be run dry and not see any oil at all.
the baffle placement is your problem
*Oil in the Pump:
The Pump is a “OIL-LESS” design, which requires NO LUBRICATION for operation. Oil in the Pump will not damage the Pump,
however it will reduce its performance. The dryer you can keep this Pump, the better it will work! The use of a baffle is mandatory!
This may require several modifications to the location and design of the baffle you draw vacuum from. How will you know if oil is in
the pump? If you use clear hose and the hose shows signs of oil in it, the oil will be in the Pump also. If you remove the belt from the
Pump and spin it by hand and you do not hear the vanes tapping (as they are flung from the rotor) you have oil in the Pump. To clean
the oil from the Pump, remove the hose from the intake side of the Pump and spray nonflammable (environmentally safe) solvent into
the intake tube with the engine running. Mind the Pump exhaust when doing this! You should make this part of your usual race car
maintenance.
Excessive oil in the pump is usually a clear indication of a failed seal or gasket. STAR Machine has a tank available that combines an
oil separator/filter and an exhaust tank in one unit, Part #02.09.000. STAR Machine will warranty this Pump for one year only when
used in conjunction with this tank.
from star
home of the
Sox and Martin Hemi Duster
Re: Where to install vacuum pump fitting on valve cover [Re: cudabin] #699475
08/10/10 12:15 AM
08/10/10 12:15 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Take this advice....avoid the Moroso breather tank at all costs...that thing will see more puke than a 17 year old keg party LOL..
Re: Where to install vacuum pump fitting on valve cover ?? [Re: HEMIFRED] #699476
08/10/10 12:18 AM
08/10/10 12:18 AM
cudabin Offline OP
cudabin  Offline OP
Hey Fred,
Yes to the Star fitting, No to the Star tank...
It is not a money thing, it is just that I was told the Star tank did not work well with Alum block, big cube Methanol injected motors.
Seems like the moroso tank does not have many fans either, but I will just have to try a different pick up spot.
Thanks,
Arnie
