What clutch fans will fit... #698925
05/16/10 12:16 AM
05/16/10 12:16 AM
Branson, Mo.
joedust451 Offline OP
super gas
super gas
Branson, Mo.
into a 71 dart with a SB, it has a 22" factory radiator, i purchased a used clutch fan assembly, but its 20" & won't really fit good, i'm trying to get rid of the solid fan, its 18", so thats what i'll need i'm sure, i do have a clutch, just need a fan, but if theres anything out there from other later Mopars that would fit & easier to find, i'd like to know? If anyone would happen to have an 18" fan for a clutch they'll let go cheap i'm all ears.
Thanks.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: What clutch fans will fit... [Re: joedust451] #698926
05/16/10 01:19 AM
05/16/10 01:19 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I think the fan blades bolt pattern is pretty much standard.
I'm most likely going to order a 19 for my Road Runner. I think I have a 17?
http://www.summitracing.com/parts/FLX-5719/
but you can do a search and if you want 18...
http://www.summitracing.com/parts/FLX-5718/
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
