440 and Edelbrock Heads
#697693
05/14/10 11:13 AM
05/14/10 11:13 AM
Posts: 602 Alexandria, VA
SealockRacing
Alexandria, VA
whats up guys, i got a few questions about my 440, and a set of eddy heads i can pick up for dirt cheap
first off, is there a way with out cc'ing the heads to know if i have the 84cc, or 88cc? is there like a number on them to go by?
also, i need help finding a set of pistons to run.
im looking to get up around 10:1 - 11:1. somewhere in there. i was thinking about some forged speedpro's, or some hyperutetic kb's. any suggestions there?
im waiting to find out if they are still available or not. ill let you guys know once i find out, if they are already gone, then i will be freshening up a set of 906's, and i would still need some help finding the right pistons to run. if you need some more info, just let me know!
John Sealock
Re: 440 and Edelbrock Heads
[Re: JohnRR]
#697698
05/14/10 12:20 PM
05/14/10 12:20 PM
Challenger 1
Cincinnati, Ohio
/first the 88cc head is an open chamber head so it's pretty easy to tell which you have by looking at it.
As far as keeping it standard bore unless the motor is VERY LOW mileage and the bores are perfect you'll be hard pressed to keep it at standard bore. Next is finding standard bore pistons, used, yes, new not so easy if at all .
g Good luck .
Yup standard bore pistons are rare to be sitting on the shelf. I was lucky enough to have a good 340 block from a 72 car that I wrecked in 77. One of my other 340s cracked a cyl wall so I pulled this block out to use and it was a 45K mile motor which sat from 1977 to 2007. I had to order some KB 243 pistons in standard bore. It took about a month to get them.
[Re: deaks]
#697702
05/14/10 04:56 PM
05/14/10 04:56 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I have a good used set of speed pro forged flat tops in good shape probly make about 10-1 comp with that setup. will sell cheap but they are .030 over
67' charger 499 RB
10.57 at 127
[Re: DaytonaTurbo]
#697704
05/15/10 08:16 AM
05/15/10 08:16 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
KB237's if you're getting the closed chambered heads. You'll want a domed piston if you're doing an open chamber head.
As for the bore thing, a machine shop can bore/hone a block for pretty cheap, then you don't have to worry about bore taper, ridge at the top of the cylinder catching the rings because you're running a different piston now, etc. Unless the motor has seen extremely low miles since the last bore job or you're going to reuse the pistons you have, I would bite the bullet and get it bored. You will not regret it.
There is no need to talk sense on this subject ...
carry on ...
