Re: 69 B Body Factory Tach Harness
[Re: foz]
#697607
05/14/10 07:46 PM
05/14/10 07:46 PM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
If your car never had a factory tach, the firewall is dimpled to the right of the bulkhead conector.
See the attached pic...it is the small grommet below the vacuum hose grommet (69 Charger)
1MYTGTX
[Re: foz]
#697610
05/15/10 06:11 AM
05/15/10 06:11 AM
1MYTGTX
S.I. N.Y.
Not sure of the exact size because IIRC there were 2 different sizes depending on year & mfg of harness. I used a stepped drill bit & drilled till she fit....
1MYTGTX
