Computer Dyno #693761
05/10/10 09:24 AM
05/10/10 09:24 AM
Liverpool, NY
SILVER67 Offline OP
SILVER67  Offline OP
Liverpool, NY
Which program do you guys use that is the most accurate computer dyno? Comp? OR someone else? I am looking for something that will allow more that just standard engine information from drop-down boxes. TX!
Michael
Re: Computer Dyno [Re: SILVER67] #693762
05/10/10 09:53 AM
05/10/10 09:53 AM
ill
dennismopar73 Offline
ill
nearest 1320
usually works best for me
never seen a dyno do 1/4 mile yet
Re: Computer Dyno [Re: SILVER67] #693763
05/10/10 10:09 AM
05/10/10 10:09 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Engine Analyzer Pro is good imo. Has a ton of inputs. you can download and use it free for 10 day's from,
http://performancetrends.com/download.htm#eapro
Re: Computer Dyno [Re: SILVER67] #693764
05/10/10 10:31 AM
05/10/10 10:31 AM
AndyF Offline
AndyF  Offline
It depends how much info you have on your motor. The really detailed programs require a ton of information.
PipeMax is a pretty good program to have if you're going to do much engine design. It was originally created for designing headers but it it pretty good in terms of predicting power output also.
Re: Computer Dyno [Re: AndyF] #693765
05/10/10 10:55 AM
05/10/10 10:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Andy do you find Pipe Max to be close... maybe I'm
just way short on their out come
Re: Computer Dyno [Re: MR_P_BODY] #693766
05/10/10 11:23 AM
05/10/10 11:23 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Pipe max confuses me (not hard to do) Wants me to use impossible size cams, way longer collectors then possible on dragster or roadster, and intake runners I could only get with a sheet metal intake.
Re: Computer Dyno [Re: supercomp] #693767
05/10/10 11:42 AM
05/10/10 11:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The program works very good for the headers... I ran
multiple sets on the dyno with good results... BUT...
you have to be able to package it
Re: Computer Dyno [Re: MR_P_BODY] #693768
05/10/10 01:31 PM
05/10/10 01:31 PM
AndyF Offline
AndyF  Offline
My motors never quite measure up to what PipeMax says they'll make but I have seen it work really well with pro-built motors. There might be some assumptions in PipeMax that have it biased towards pro type motors. Those motors tend to have less internal friction, lighter parts, etc.
Re: Computer Dyno [Re: AndyF] #693769
05/10/10 03:05 PM
05/10/10 03:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I guess so... but I am quite a bit lower than the min
spec but it could be just my building... I;m a 100 HP low
Re: Computer Dyno [Re: MR_P_BODY] #693770
05/10/10 05:07 PM
05/10/10 05:07 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
I was real close to the average hp but headers, cam and intake were no where near what he suggested.LOL
Re: Computer Dyno [Re: supercomp] #693771
05/10/10 05:20 PM
05/10/10 05:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I know my cam is small... its .700 lift and I knew I
should have gone to about .760... the program said .800
plus... but I didnt want to have to change springs on a
regular basis... I am thinking about having it re-ground
but I also cant believe it would have killed over
100+ HP... guess I was wrong... AGAIN
Re: Computer Dyno [Re: MR_P_BODY] #693772
05/10/10 05:39 PM
05/10/10 05:39 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
According to Pipemax I've never been right about anything. Think of the hp if I would just listen.
Re: Computer Dyno [Re: supercomp] #693773
05/11/10 05:15 PM
05/11/10 05:15 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
So are we saying pipemax is good or? how much is it and where can i get it? I've always wanted a comp dyno to play around with.
Re: Computer Dyno [Re: Diablo] #693774
05/11/10 07:55 PM
05/11/10 07:55 PM
NH
Fastback67 Offline
Fastback67  Offline
NH
Engine Analyzer Pro is the most accurate program that I have used yet. However, as one member here has already stated... it's not exactly a user friendly program, and requires a great deal of highly detailed information to be accurate. Good program for the professional engine builder.
Re: Computer Dyno [Re: SILVER67] #693775
05/11/10 11:41 PM
05/11/10 11:41 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have been using Dynomation 5, and it is OK. I think it costs $399.
http://www.motionsoftware.com/Dynomation5.htm
