Re: 265/60/15 and 225/70/15 on stock 74 Duster
[Re: KGorney]
#693705
05/10/10 07:48 AM
05/10/10 07:48 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
""265/60/15 on the back""
May I ask what brand makes this size? When I was looking a couple of years ago I could not find this size, so I ended up with 255/60/15's on back. Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: KGorney]
#693707
05/10/10 11:56 AM
05/10/10 11:56 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
that sounds aweful tall on the front for a duster. my duster with 14x5.5" rallyes only has room for 205-215/70R14 tires up front before you'd have to start trimming the front edge of the wheel opening. a 225/70R15 will be another 1.25" taller....I'd probably look at 225/60R15's for the front.
[Re: patrick]
#693708
05/10/10 12:29 PM
05/10/10 12:29 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
I agree too tall. 225/60/15 will be close. Close will vary close depending on alignment, past collision damage and bodywork to fenders. Turn the tire so the edge is closest to the front fender bottom lip. Then back up down a driveway with the tire in that closest position while someone watches for clearance.
I really do not think 225/60/15 will work with 3.75 backspace 15x7 rims.. You need to run a 15x7 4.25 to 4.5 backspace rim. You could give 4.0 backspacing a try, but don't get your hopes up unless you want to lip back 1/2" of the bottom front edge of the fender lip. OR see if you could push out the fender with the bottom fender stabilizer bar a bunch (drill new hole in fender).
[Re: Kern Dog]
#693712
05/11/10 01:09 AM
05/11/10 01:09 AM
autoxcuda
So Cal
My stock wheelwell 74 FRANKENDUSTER has 235 60 15 BF Goodrich tires on stock 15x6.5 ralley wheels up front. They fit fine. The rear? 255 60 15 tires on widened 15" wheels from Wheel Vintiques.
I think 15x6.5 rallyes are 4.25 backspacing. The original poster has 15x7 with 3.75 backspacing.
Re: 255/60/15 and 225/70/15 on stock 74 Duster
[Re: KGorney]
#693716
05/11/10 02:57 PM
05/11/10 02:57 PM
Posts: 7,859 Witness Protection Program
Kudakidd
Hey Keith, I'm running almost exactly what you're planning on installing. I have a set of 15x8 Jeg's Sport Drag rims with 255/60-15 tires,and this combo would work best for a stock rear suspension A body. These back rims have 4-1/2" backspacing. The fronts are the same brand rim, but are 15x7, with 4" back spacing. The largest front tire you can use w/o rubbing or hitting something are 215/70-15's (which is what I'm using after some experimentation). KK
[Re: Kudakidd]
#693717
05/11/10 04:54 PM
05/11/10 04:54 PM
Posts: 1,891 PA
KGorney
PA
