98 dodge 4x4 #692820
05/08/10 10:40 PM
05/08/10 10:40 PM
Brandon, Manitoba, Canada
Roadripper Offline OP
hi there i have a 98 dodge 4x4 1500 witch has a 318 with a puked 4sp auto trans. I have a chance to buy a 91 dodge 4x4 cummins 5spd (with 350000km on it) this truck has a puked transfer case in it !! was wondering if it would be worth my time to convert the gas powered 98 into a cummins powered 98 ???
> would my auto trans transfer case fit the 5 speed standard?
> would the computer stuff for the 91 adapt to the 98 stuff??
any help would be great thanks Mike
Re: 98 dodge 4x4 [Re: Roadripper] #692821
05/09/10 03:51 AM
05/09/10 03:51 AM
Bennett, Colorado
Charger69RT8 Offline
Bennett, Colorado
You state that your truck is a 1500 , ie 1/2 ton. The reason that the cummins was never offered in 1500's is they are too heavy for that pickup. Note that 2500's & 3500's have larger frames, heavier suspensions and bigger axles than 1500's. Not saying it can't be done, just that in my oopinion your truck ain't bulit stout enough for this swap.
As for your other questions I'll have to let somebody else address that.
2012 Challenger SRT
2012 Charger SXT AWD
69 Charger R/T
78 Chrysler New Yorker 440CI
89 Dodge Daytona ES 2.5L Turbo
99 Ram 2500 4X4 5.9L6
