Installing a 4 blade fan relay-need diagram.
#691945
05/07/10 11:20 PM
05/07/10 11:20 PM
Posts: 6,847 Missouri
StrokerPost
Missouri
I need visual diagram of what wires go on what blades. Had one, but cant find it. Thanks, Ken.
Re: Installing a 4 blade fan relay-need diagram.
[Re: StrokerPost]
#691946
05/07/10 11:31 PM
05/07/10 11:31 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
It should be on the side of the relay.
Or did you want it wired out?
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: StrokerPost]
#691949
05/08/10 12:29 AM
05/08/10 12:29 AM
Posts: 7,759 So Cal
HealthServices
So Cal
This should work if you want to turn on the fans earlier or keep them running.
Just be careful to shut it off otherwise it will kill your battery if left on.
Allen
[Re: HealthServices]
#691950
05/08/10 12:30 AM
05/08/10 12:30 AM
Posts: 7,759 So Cal
HealthServices
So Cal
Or if you want the manual over ride to work only when the ignition is on.
Allen
