Page 5 of 19 1 2 3 4 5 6 7 18 19
Re: Pics of your lowered 72-93 Dodge trucks [Re: 76dodgeboy] #691391
09/19/10 08:54 PM
09/19/10 08:54 PM
MO
C_Notch Offline
C_Notch  Offline
MO
I used a 1" spacer that changed the bolt pattern from 5x4.5 to 5x5.5. Spacer sets them out just enuff that the rears dont rub. No turning issues either.
Re: Pics of your lowered 72-93 Dodge trucks [Re: C_Notch] #691392
09/20/10 12:32 AM
09/20/10 12:32 AM
Iowa
76dodgeboy Offline OP
Iowa
Ok.
Re: Pics of your lowered 72-93 Dodge trucks [Re: 76dodgeboy] #691393
09/23/10 07:25 AM
09/23/10 07:25 AM
Germany
1964Polara Offline
1964Polara  Offline
Germany
Nice! I lowered it a little more and a little custom work
What did you do to drop it more?
Re: Pics of your lowered 72-93 Dodge trucks [Re: 1964Polara] #691394
10/01/10 06:23 PM
10/01/10 06:23 PM
Dirty Dena, Maryland
dodge turbo Offline
dodge turbo  Offline
Updated pic of mine from page one
-put the rear on top of the springs and put the stock shackles on the back and returned the front spring hangers to stock. Also added Caltrac bars. Rancho adjustable in back
-Front van lower control arms. New MOOG springs with one coil removed
-Rear center of wheel well is 27" from the ground
-Front is 25" from the ground
Rear tires are Hoosier radial slicks 30x9
Front tires are Cooper 215/75/15 (28 inch tall)
I had to but the bump stop mounts off the front because the where sitting on the strut rods. the ride height stayed the same after if cut them.
I have about 3inchs of clearance in rear from the rear to the frame. i had my father (230lbs) and brother (220) stand in the back and jump up and down and never came close to hitting.
This is the only pic i have from my cellphone..im using my crapy laptop so i wont have any good ones any time soon
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: Pics of your lowered 72-93 Dodge trucks [Re: dodge turbo] #691395
10/02/10 04:27 AM
10/02/10 04:27 AM
lakeside ca
1moparman Offline
1moparman  Offline
lakeside ca
love it would love to see the turbo set up as well!
Get Real Get Mopar
Re: Pics of your lowered 72-93 Dodge trucks [Re: dodge turbo] #691396
10/02/10 11:11 AM
10/02/10 11:11 AM
Iowa
Iowa
That looks sweet. Need some dogdish caps now
Re: Pics of your lowered 72-93 Dodge trucks [Re: 76dodgeboy] #691397
10/02/10 04:22 PM
10/02/10 04:22 PM
dodge turbo Offline
dodge turbo  Offline
ask and you shall receive....
Not to fond of the dog dish caps...sorry
Re: Pics of your lowered 72-93 Dodge trucks [Re: dodge turbo] #691398
10/02/10 04:24 PM
10/02/10 04:24 PM
dodge turbo Offline
dodge turbo  Offline
cal trac setup because i know that will be the next request...lol
Re: Pics of your lowered 72-93 Dodge trucks [Re: dodge turbo] #691399
10/02/10 06:49 PM
10/02/10 06:49 PM
lakeside ca
1moparman Offline
1moparman  Offline
lakeside ca
I know what you mean I think my truck looks just as good without them I like the cop car ones with the holes but everyone wants a fortune, your truck does look great didn't realize it was a step side before because all the pics I saw was of the front, how many pounds of boost are you running and can you tell us a little more about your setup.
Get Real Get Mopar
Re: Pics of your lowered 72-93 Dodge trucks [Re: 1moparman] #691400
10/03/10 08:22 AM
10/03/10 08:22 AM
dodge turbo Offline
dodge turbo  Offline
360-.30 over 73 block
-8:1 ross coated pistons
-stock x-heads with vavle job
-comp cam (custom turbo)
-m-1 intake
-self modded 750dp carb
turbo setup
-flip pacesetters headers for a 94-02 ram
-self made cross over pipe
-4inch single downpipe/exhaust
-Borg warner s400 75mm w/.1.10 exh housing
4inch core vsracing intercooler (ebay brand)
8psi so far at the track 11.0's@125 w/2.0 60ft on bfg drag radials
will go 15psi plus with c-16..couldnt get it to hook at all before thats why only 8psi...and thats why i flipped the rear and put cal tracs on it and just wanted it to sit on the ground more
Re: Pics of your lowered 72-93 Dodge trucks [Re: dodge turbo] #691401
10/03/10 01:03 PM
10/03/10 01:03 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Here's mine. No photo tricks. The real thing.
Re: Pics of your lowered 72-93 Dodge trucks [Re: TooMany62s] #691402
10/03/10 03:10 PM
10/03/10 03:10 PM
bonney lake WA
dmopar74 Offline
dmopar74  Offline
bonney lake WA
work in progress...
Re: Pics of your lowered 72-93 Dodge trucks [Re: dmopar74] #691403
10/03/10 03:43 PM
10/03/10 03:43 PM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
Friends truck here in Texas
Re: Pics of your lowered 72-93 Dodge trucks [Re: bigdad] #691404
10/03/10 03:44 PM
10/03/10 03:44 PM
S.E. South Dakota !
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Front
Re: Pics of your lowered 72-93 Dodge trucks [Re: bigdad] #691405
10/03/10 03:45 PM
10/03/10 03:45 PM
S.E. South Dakota !
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Power source
Re: Pics of your lowered 72-93 Dodge trucks [Re: bigdad] #691406
10/04/10 07:39 PM
10/04/10 07:39 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
need more pics
Re: Pics of your lowered 72-93 Dodge trucks [Re: dodge turbo] #691407
10/06/10 07:48 AM
10/06/10 07:48 AM
Germany
1964Polara Offline
1964Polara  Offline
Germany
Looks really good and low!!!!!!!
NO clearance issues in the front?????
Re: Pics of your lowered 72-93 Dodge trucks [Re: 1964Polara] #691408
10/06/10 12:00 PM
10/06/10 12:00 PM
dodge turbo Offline
dodge turbo  Offline
i had to cut the bump stop brackets off...i might end up getting another set of springs and only doing half a coil....i havent really driven it at yet...but as far as i can tell nothing rubs or hits yet knock on wood
Re: Pics of your lowered 72-93 Dodge trucks [Re: dodge turbo] #691409
10/06/10 12:10 PM
10/06/10 12:10 PM
Germany
1964Polara Offline
1964Polara  Offline
Germany
OK would love to know if driven everything is fine too...
Re: Pics of your lowered 72-93 Dodge trucks [Re: dodge turbo] #691410
10/08/10 07:20 PM
10/08/10 07:20 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Winner
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
