UPDATE.... this is getting interesting..
Pulled the plugs,they all looked about the same. Weird... Saw a little bit of oil on the valley pan..Pulled the intake. Look through the intake ports down at the valves. 6 of the 8 valves had fuel puddled in the seat. Wow..this might explain why when the car sits after running its a pain to start... Ah why i got the carb off let me just throw a different carb on. I replaced the holley with an eddy 600.
I run the car in the drive way... 5 minutes.. monitoring tempatures..10 minutes watching the coolant cycle ,15-20 minutes car is still at 170 highest at idle.
Wow...lets not get to excited..hop in the car go for a cruize,some stop and go but mainly 60mph roads, a good 30 min drive with some wide open passes . Car never got over 180. I idled it when i got back in the driveway for another ten minutes and it got to 185 but never higher and thats sitting after the beat down. I shut it down, and let it sit for 10 minutes. Did a relight and it lit right up instantly. Never would of done that before. Im going to keep my fingers crossed and the next HOT day try it out and see what happens...
