Hemi Positioning On Engine Stand
#690828
05/06/10 11:07 PM
05/06/10 11:07 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
How do you position your engine on the engine stand? Here is a picture of mine. The block is bare and the heads are bare. This thing is so top heavy, I can't rotate it without it flipping upside down. I put the heads on for storage. Will this setup work once the block is complete? Any suggestions are welcomed. I am too old to arm wrestle the Hulk.
Re: Hemi Positioning On Engine Stand
[Re: '72CudaRacer]
#690830
05/07/10 12:05 AM
05/07/10 12:05 AM
Posts: 3,505 DFW
mr_340
DFW
The last 340 I built flipped around on me and pinched my finger between one of the bars and the rear plate. I was lucky not to lose a finger. I decided to buy a gear drive engine stand to put my Hemi together. I bought one from Summit. http://www.summitracing.com/parts/SUM-908300GA/
Floyd Lippencott IV
[Re: mr_340]
#690831
05/07/10 12:30 AM
05/07/10 12:30 AM
Snoopy
I was hoping to reposition the mount to get closer to the center of gravity. It looks like the CG is closer to the cam, that will require me to rotate the mounting plate 180 deg and use the mounting holes on the block at 9 & 3 o'clock.
[Re: Snoopy]
#690837
05/07/10 07:24 AM
05/07/10 07:24 AM
Challenger 1
Cincinnati, Ohio
Need to use the upper bolt holes for sure, yup the cheaper stands are made for SB chevys it seems. Like Andy, I built my own stand in welding shop in hi school my senior year off of plans we had at school. I had no idea it would turn out to be such a good stand 30 years later. I have had many different engines on this stand including International gas truck engines which make hemis appear small. I think OTC makes some decent stands if you don't want to either build one or have one built. It's a little taller than factory made ones which helps since I'm 6'3". And I know the difference because when I'm busy I have to use this store bought stand which I would never hang a hemi on.
