Page 2 of 6 1 2 3 4 5 6
Re: Body paint [Re: Dartman440] #690061
06/07/10 11:08 AM
06/07/10 11:08 AM
Southern Michigan
Dartman440 Offline OP
Southern Michigan
Awesome paint by Brad Rutkowski,Brighton.Mich.
Re: Body paint [Re: Dartman440] #690062
06/07/10 11:09 AM
06/07/10 11:09 AM
Southern Michigan
Southern Michigan
Deck lid stripe
Re: Body paint [Re: Dartman440] #690063
06/07/10 11:11 AM
06/07/10 11:11 AM
Southern Michigan
Southern Michigan
Almost in this pic
Engine [Re: Dartman440] #690064
06/07/10 11:59 AM
06/07/10 11:59 AM
Southern Michigan
Southern Michigan
The engine is a custom hand built all new 528 Hemi By the Late Great Ramchargers record holder Dean Nicopolis. He was the best in the business.A great guy with a big sense of humor. He is sadly missed. All components are new. It is a special grind cam that Dean came up with. His cams were all made for him out of billet stock by a guy in Missouri. The block is all epoxy painted inside so the oil runs back down fast. A lot of small mods were made to the block that you do not get with a crate engine. The heads had some work done to them also. Custom valve springs. All new Ferrara Stainless valves.Dick Landy Roller rockers. 440 Source Stroker crank. A set of new steel Hemi rods Dean had. rods. Arias 10:5 to 1 forged pistons. All balanced. Mopar Perf. Single plane intake with a few mods. All was assembled and done with TLC. This motor cranked out 700 H.p. on pump gas with room for lots of improvement. It is a hydralic roller cam that was not that radical. Great idling characteristics with lots of torque. The carb is a new Demon 850DR. New stock Hemi mechanical fuel pump. Stock 70 wrinkle valve covers were used in the end to clear the shock towers. All aluminum water pump housing were used. MSD Dist and Ignition.
Re: Body paint [Re: Dartman440] #690065
06/19/10 09:22 PM
06/19/10 09:22 PM
ohio
70shaker6pk Offline
super gas
70shaker6pk  Offline
super gas
ohio
Very very NICE!!!!!
Re: Body paint [Re: 70shaker6pk] #690066
11/25/10 10:36 PM
11/25/10 10:36 PM
mn
N
nates69b Offline
nates69b  Offline
N
mn
man, i just found this post, do you have any more pictures, id love to see this one done. the coolest e body build ive seen.. i love it. love the color and the style, what wheels are you putting on it?
Re: Body paint [Re: Dartman440] #690067
11/28/10 12:07 AM
11/28/10 12:07 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I love that color combo!!
Re: Body paint [Re: YO7_A66] #690068
12/07/10 11:48 AM
12/07/10 11:48 AM
Southern Michigan
Southern Michigan
Hi Guys, Thanks, I think it is the coolest build yet. That is a rare color combo. One of 5 I believe.Probably the only 4 speed built. The wheels are HRE 645's custom made for this car. These were the most balanced and perfect made wheels I have seen.18x9 Fronts. 18x10 rears. Tires are BF Goodrich G force.
Re: Body paint [Re: Dartman440] #690069
12/07/10 02:26 PM
12/07/10 02:26 PM
Southern Michigan
Southern Michigan
Here is a shot of the tire.
Re: Body paint [Re: Dartman440] #690070
12/07/10 02:33 PM
12/07/10 02:33 PM
Southern Michigan
Southern Michigan
Here is a shot of the floor pans. They were like glass.
Re: Body paint [Re: Dartman440] #690071
12/07/10 02:35 PM
12/07/10 02:35 PM
Southern Michigan
Southern Michigan
Another, You can see the XV MotorSports frame ties and how nice they look and fit.
Re: Body paint [Re: Dartman440] #690072
12/07/10 02:36 PM
12/07/10 02:36 PM
Southern Michigan
Southern Michigan
Ready for Suspension Assy.
Re: Body paint [Re: Dartman440] #690073
12/07/10 02:38 PM
12/07/10 02:38 PM
Southern Michigan
Southern Michigan
Engine is dropped in the K Member and ready to put all goodies on.
Re: Engine assy. [Re: Dartman440] #690074
12/07/10 02:39 PM
12/07/10 02:39 PM
Southern Michigan
Southern Michigan
Almost ready.
Re: Engine assy. *DELETED* [Re: Dartman440] #690075
12/07/10 03:11 PM
12/07/10 03:11 PM
Southern Michigan
Southern Michigan
Post deleted by Dartman440
Re: Engine comp [Re: Dartman440] #690076
12/07/10 03:15 PM
12/07/10 03:15 PM
Southern Michigan
Southern Michigan
The New Dana 60 with 4:10's. XV Rear Disc Brakes.
Re: Engine comp [Re: Dartman440] #690077
12/07/10 03:16 PM
12/07/10 03:16 PM
Southern Michigan
Southern Michigan
Installed
Re: Engine comp [Re: Dartman440] #690078
12/07/10 03:20 PM
12/07/10 03:20 PM
Southern Michigan
Southern Michigan
Engine and K member assy. are in.
Re: Engine comp [Re: Dartman440] #690079
12/07/10 03:28 PM
12/07/10 03:28 PM
Southern Michigan
Southern Michigan
MSD Full Ignition. 950 Demon Carb. KOOK Stainless Steel headers and KOOK 3 inch stainless exhaust.And 3" inch Stainless Dynomax Mufflers.. They have the nicest mandrel bent exhaust.Custom Built Aluminum Rad. 2 Spal Electric fans with new state of the art controller.They are super quiet and work the best.
Re: Fans. [Re: Dartman440] #690080
12/07/10 03:34 PM
12/07/10 03:34 PM
Southern Michigan
Southern Michigan
Spal Fans
