Shifter Rod Question #689940
05/06/10 07:28 AM
05/06/10 07:28 AM
Tony440 Offline OP
Tony440  Offline OP
Does anyone have a photo of the shifter rod that connects the trans lever to the torque shaft on a 727 with a console. I have a 67 Coronet R/T that has a Hurst dual gate shifter on it. I would like to put the factory shifter and console back in the car. I have all of the linkages and am wondering if the rod I have is correct. Also if anyone has photos of the shifter and linkages without the console installed that they could post, that would be helpful. Is the shifter rod for a 727 and big block a different length, than the rod that's used on a 904 and a small block? Thanks in advance for the help!
Re: Shifter Rod Question [Re: Tony440] #689941
05/06/10 09:21 AM
05/06/10 09:21 AM
Tony440 Offline OP
Tony440  Offline OP
Anyone?
