'85 ramcharger build #689930
05/06/10 12:17 AM
05/06/10 12:17 AM
arizona
fmcgraugh2 Offline OP
arizona
Okay im rebuilding an 89 360 roller la style motor to go in my 1985 ramcharger. im running a 60711 lunati cam new heads from Aero head racing with the cast #4027596-A on them. An eddy performer intake with 600 cfm eddy carb. A 727 freshly rebuilt trans w/ high stall stock TC will be sitting behind the 360. Tire size is 235 75r15. The rear end im told is 294. ( a 3.55 will be put in the future) This is my first mopar and first full engine rebuild. Crank and pistons are only things not replaced. Which filter and oil additive should i use in the new motor. And which way do i turn the oil pump in order to prime the motor. Im really sorry its such a long post but if i screw this motor up ill be divorced LOL
Re: '85 ramcharger build [Re: fmcgraugh2] #689931
05/06/10 08:16 AM
05/06/10 08:16 AM
scratchnfotraction Offline
IIRC clock wize on the oil primer
wix filter and some eso additive or the like
I would get a better intake with that cam
IMHO an LD340 or a airgap rpm from eddy
the plane jane performer is gonna hold it back
I had one on mine with the lunati 60710 roller cam and when I put the LD on ...night and day differance
wont be going with a performer ever again
OH! and a roller cam and roller lifters do not need a break in like a flat tappet cam either
so some good oil is all thats needed
