Re: Strange axle Dana 60 questions
[Re: dave571]
#689927
05/06/10 12:32 AM
05/06/10 12:32 AM
Posts: 127 California
Moneypit6
California
Okay, so I assume I should put the gasket between the backing plate and the housing flange. Then I can just use a little anti-sieze between the backing plate and the retaining ring. Sound good?
Also, reason I asked about the axle sliding off was that once I unbolted the retaining ring, the axle would fairly easily slide out 1/4 to 1/2 inch and then stop. I didn't want to force it without knowing if there was something on the inside by the carrier that retained it as well.
Dennis
70 Roadrunner almost ready to come off the rotisserie
