Re: Reassembling Mopar Distributor
[Re: 469runner]
#689763
05/05/10 10:44 PM
05/05/10 10:44 PM
RapidRobert
Havent have the privilege (or the cash) to work on a Mallory unit yet but on the oe ones I pry up on the top plate in the right spot/slight amount so it'll slip in. Good luck w it.
[Re: RapidRobert]
#689764
05/05/10 11:40 PM
05/05/10 11:40 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
is the same on MP units The pick up plates and vacuum pods are the same on MP than standart units. Basically the only diff is the counterweights design for custom setup.
