HV or stock oil pump? #689577
05/05/10 03:21 PM
05/05/10 03:21 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Hello, getting ready to order some more parts for the street motor. And was curious, is there any benefit to a HV pump in a mild street motor with stock oiling system including 3/8 inch pickup? This motor will never see above 6000rpm if that. Thanks
Re: HV or stock oil pump? [Re: 70VcodeCoronetRT] #689578
05/05/10 03:29 PM
05/05/10 03:29 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
IMO, you would be fine with a stock pump. If you use a stock sump pan with a high volume pump, be sure and keep a check on your oil level.
I have a new melling oil pump in my 318 that is stock volume. It holds around 60psi till it gets good and warmed up and then doesnt drop much below that
Re: HV or stock oil pump? [Re: 70VcodeCoronetRT] #689579
05/05/10 03:34 PM
05/05/10 03:34 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Recently rebuilt or stock crank/bearings? A tired motor will benefit from a hv pump because the extra oil flow is a patch for worn bearings. Also, an engine with fully grooved bearings will also use the extra oil flow.
Re: HV or stock oil pump? [Re: DaytonaTurbo] #689580
05/05/10 03:42 PM
05/05/10 03:42 PM
Nebraska
Nebraska
This will be for a fresh rebuild with a 6qt hemi pan.
Re: HV or stock oil pump? [Re: 70VcodeCoronetRT] #689581
05/05/10 05:38 PM
05/05/10 05:38 PM
Sealed power std vol/std psi spring
